At least one problem with the 2.54 mm headers is the choice of pins or sockets. I prefer the sockets because they work with the male-male jumpers I use with Arduinos.
Any shop that deals in arduinos is a good source for 2.54 mm headers, Adafruit and nskelectronics are two I use as well as sparkfun.
VoCore Breakout Board
- Greenwire-Elektronik
Re: VoCore Breakout Board
Yeah, i might should post some links to webshops which have 2.54mm (0.100") pin headers in stock.
In other news:
I got plenty of pin headers in stock - also higher order quantities can be delivered fast!
In other news:
- Endat
Greenwire-Elektronik wrote:How did you connect your VoCore now?
Sorry for late response.. I connect the same way as before, only with a new VoCore all of the GPIO work. On my other VoCore, I wore out some GPIO with IC hooks and that's why some didnt work.
Also when I soldered the pin headers onto the breakout board, I had the VoCore attached on the opposite side with sockets in place to keep perfect alignment.
Meanwhile 77 boards were sent all over the world. This means that ~20 are left before i would have to invest again. So what have you done with them? Do you want to buy some more? Share your usage
- johnm
sorry if this question was already answered - the 2.54mm pins, are they just the ones on the breakout board, or are they what are used to connect to vocore to the breakout?
I ask because I thought the vocore needed 1.27mm pins?
haven't received my vocore yet, so I'm still not 100% sure what to get...the data info says 1.27?
Yes, VoCore need 1.27mm pins.
Use the breakout board can be covert to 2.54mm pins.
Users browsing this forum: No registered users and 11 guests
