TTL to USB Converter
haraldn
Tue Nov 18, 2014 12:31 pm
The TTL to USB Converter as put in the package does not work in Windows 8.1! Please consider this....
Peter H
Re: TTL to USB Converter
Wed Nov 19, 2014 3:20 pm
I haven't tried it in 8.1. Is it a USB driver problem? If so, perhaps you could use Microsoft's Virtual PC emulation to run the USB driver in an XP compatible environment.
haraldn
Wed Nov 19, 2014 3:39 pm
The homepage of the chip states that Win8.1 is not supported anymore and that newer chip versions should be used. In the Device Manager a yellow exclamation mark occurs. It's no problem for me because I have another converter - I just want to mention...
wangnick
Mon Nov 24, 2014 7:57 pm
It works also on Windows 8.1 if you install the older version 1.5.0 of the Prolific PL2303 driver. There are some sites hosting it that can be found by googling. The exact name is PL2303_Prolific_DriverInstaller_v1.5.0.exe , it's size is 3.223.429 Bytes.
Kind regards, Sebastian
Users browsing this forum: No registered users and 388 guests
