No WiFi any more
- Ingmar
Re: No WiFi any more
[Solved]: I could connect through the wired port. resetting to the defaults apparently disables the wifi.
Maybe /etc/config/wireless setting disabled wifi?
I think it is not hardware issue if you did not change anything, but if you solder wire onto vocore with high heat(>300C), it has very low chance to broken the wireless.
Users browsing this forum: No registered users and 20 guests
