I've compiled openwrt with kmod-usb-hid support as indicated here: http://h-wrt.com/en/doc/kb
but I run into a few problems.
First, the repositories generated are all broken in opkg.conf. I replaced them with the one from nobilepepper as found here: viewtopic.php?f=2&t=262&start=10
that provided a few working packages but the one I need is still absent. Is this something I'm going to need to find and compile?
Thanks for the help, I'm really loving this platform.
Where to find kmod-usb-hid package?
- aarobc
Re: Where to find kmod-usb-hid package?
I compiled asnd installed that package without any problem. Maybe get the new openwrt trunk and compile full source again will fix such problem?
I don't remember why I didn't include kmod-usb-hid in the repositories I put together, but you are quite correct it is not there.
What do you mean by
You may want to look at opkg update doesn't work.
If you want to use a package you built you need to transfer it to the vocore and then reference it by the full pathname.
In debian I:
Then on the vocore I:
What do you mean by
? What does your opkg.conf look like?the repositories generated are all broken in opkg.conf
In debian I:
scp bin/ramips/packages/base/kmod-usb-hid_3.18.7-1_ramips_24kec.ipk root@192.168.x.xxx:/root
opkg install /root/kmod-usb-hid_3.18.7-1_ramips_24kec.ipk
- aarobc
The listed repos weren't resolving. I replaced them with the ones that you listed and it installed and worked great, much appreciated.
Users browsing this forum: No registered users and 68 guests
