Ethernet connected but 'Network is unreachable'
harrisonhjones
Tue Dec 02, 2014 9:54 pm
Hey everyone,
I have an issue, the VoCore is having problems connecting to the internet. My setup is this: Stock vocore w/ dock.
Internet <-> Cable Modem <-> Router <-> Vocore (lan) <-> My Laptop (vocore wifi).
My laptop is connected to the SSID "vocore" and has the internet (I'm writing this from it now) but when I log into the Vocore using the UART I get a "Network is unreachable" if I ping anything other than the local loop back. Here's my ifconfig -a. What's going on?
br-lan    Link encap:Ethernet  HWaddr B8:D8:12:60:00:01
          inet addr:192.168.61.1  Bcast:192.168.61.255  Mask:255.255.255.0
          inet6 addr: fdc4:df4c:3dd2::1/60 Scope:Global
          inet6 addr: fe80::bad8:12ff:fe60:1/64 Scope:Link
          RX packets:3026 errors:0 dropped:0 overruns:0 frame:0
          TX packets:598 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:242326 (236.6 KiB)  TX bytes:171131 (167.1 KiB)
eth0      Link encap:Ethernet  HWaddr B8:D8:12:66:0A:BA
          inet6 addr: fe80::bad8:12ff:fe66:aba/64 Scope:Link
          RX packets:7174 errors:0 dropped:0 overruns:0 frame:0
          TX packets:5251 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:4587826 (4.3 MiB)  TX bytes:1254308 (1.1 MiB)
          Interrupt:5
eth0.1    Link encap:Ethernet  HWaddr B8:D8:12:66:0A:BA
          TX packets:5236 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:4458694 (4.2 MiB)  TX bytes:1220778 (1.1 MiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:1842 errors:0 dropped:0 overruns:0 frame:0
          TX packets:1842 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:125776 (122.8 KiB)  TX bytes:125776 (122.8 KiB)
wlan0     Link encap:Ethernet  HWaddr B8:D8:12:66:0A:BA
          RX packets:6132 errors:0 dropped:0 overruns:0 frame:0
          TX packets:8766 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:1316647 (1.2 MiB)  TX bytes:5085113 (4.8 MiB)
My local network is 10.0.0.XXX. My laptop (behind the Vocore's wifi is assigned a valid 10.0.0.XXX address but the vocore itself doesn't seem to be.
Re: Ethernet connected but 'Network is unreachable'
Wed Dec 03, 2014 5:10 pm
This might be firewall problem. Not sure about that, just enable forward, it should be ok.
Peter H
Wed Dec 03, 2014 6:01 pm
Has the VoCore acquired a network address on the Ethernet port? Assuming your router is acting as a DHCP server, you should be able to see your VoCore in the router's list of DHCP clients.
harrisonhjones
Fri Dec 05, 2014 3:42 am
I realize this won't be a helpful reply but I ended up figuring out the issue. I setup the core in AP+STP mode and from there I was good to go
Users browsing this forum: No registered users and 43 guests
