Ethernet connected but 'Network is unreachable'
Posted: Tue Dec 02, 2014 9:54 pm
Hey everyone,
I have an issue, the VoCore is having problems connecting to the internet. My setup is this: Stock vocore w/ dock.
Internet <-> Cable Modem <-> Router <-> Vocore (lan) <-> My Laptop (vocore wifi).
My laptop is connected to the SSID "vocore" and has the internet (I'm writing this from it now) but when I log into the Vocore using the UART I get a "Network is unreachable" if I ping anything other than the local loop back. Here's my ifconfig -a. What's going on?
My local network is 10.0.0.XXX. My laptop (behind the Vocore's wifi is assigned a valid 10.0.0.XXX address but the vocore itself doesn't seem to be.
br-lan Link encap:Ethernet HWaddr B8:D8:12:60:00:01
inet addr:192.168.61.1 Bcast:192.168.61.255 Mask:255.255.255.0
inet6 addr: fdc4:df4c:3dd2::1/60 Scope:Global
inet6 addr: fe80::bad8:12ff:fe60:1/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3026 errors:0 dropped:0 overruns:0 frame:0
TX packets:598 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:242326 (236.6 KiB) TX bytes:171131 (167.1 KiB)
eth0 Link encap:Ethernet HWaddr B8:D8:12:66:0A:BA
inet6 addr: fe80::bad8:12ff:fe66:aba/64 Scope:Link
RX packets:7174 errors:0 dropped:0 overruns:0 frame:0
TX packets:5251 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4587826 (4.3 MiB) TX bytes:1254308 (1.1 MiB)
Interrupt:5
eth0.1 Link encap:Ethernet HWaddr B8:D8:12:66:0A:BA
TX packets:5236 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:4458694 (4.2 MiB) TX bytes:1220778 (1.1 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1842 errors:0 dropped:0 overruns:0 frame:0
TX packets:1842 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:125776 (122.8 KiB) TX bytes:125776 (122.8 KiB)
wlan0 Link encap:Ethernet HWaddr B8:D8:12:66:0A:BA
RX packets:6132 errors:0 dropped:0 overruns:0 frame:0
TX packets:8766 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:1316647 (1.2 MiB) TX bytes:5085113 (4.8 MiB)
