Can't connect with TTL
ad7zj
Tue Dec 01, 2015 5:38 am
Using the supplied TTL adapter hooked up as shown here http://vocore.io/wiki/index/id:14
Putty configured with 57600 8N1. It's just printing out garbage, see the screenshot. Any ideas? I've tried all the common baud rates just for the heck of it but none of them give a successful decode. I messed up the network settings and can't get in via the wifi :(
Re: Can't connect with TTL
Tue Dec 01, 2015 8:05 am
Looks like GND is not connect together.
ad7zj
Thu Dec 03, 2015 2:31 am
But it is, I've checked the connections so many times. Even verified with an ohmeter. See attached picture... I tried using the power supply ground as well but that didn't work at all...
ad7zj
Thu Dec 03, 2015 3:01 am
Disregard, I figured it out. I was counting from the header pins, missing the first via...
Anyway I'm in via the serial console now, trying to figure out what to reset. I tried to bridge the wired and wireless connections from LUCI which was when I got locked out.
ad7zj
Thu Dec 03, 2015 7:35 am
Got that sorted too, run 'firstboot' to reset factory defaults.
Thu Dec 03, 2015 1:56 pm
Looks like you connect the wrong port, the black wire(GND I guess)should connect to the hole under it.
And also RX, TX both should connect the hole under it
check the pin map.
http://vocore.io/images/vocore.introduce_.jpg
Users browsing this forum: No registered users and 35 guests
