LEDs are off after boot
Posted: Mon Jan 04, 2016 11:12 pm
after flashing my first self-compiled OpenWRT image for the VoCore the green status LED is not lit after booting. First I feared that I bricked my VoCore but it boots and establishes the WiFi client connection successfully.
I tried to change the LED brightness but without any effect:
Now I do not know if something went wrong with the image (missing setting?) or if it is related to the removing of the dock and the RX and TX pins.
The fact that it is still working is most important but some visual indication would be good.
My steps:
1. checked out chaos calmer git
2. loaded and installed feeds
3. applied patch
4. make menuconfig and select libpthread
5. flashed
After first boot and no LED status indication I removed the RX and TX pins from the dock to connect the TTL2USB and figured out that it is still alive.During boot the LEDs show existence but are turned off when it is running.
Thank you
echo 255 > /sys/devices/gpio-leds/leds/vocore\:green\:status/brightness
My steps:
3. applied patch
5. flashed
Thank you
