Unable to change GPIO values or directions
allanmitch
Sun Jan 31, 2016 2:57 pm
I have a Vocore with Dock v2. I'm trying to make a doorbell that sends me a notification that someone rings the doorbell. But I'm having problems changing the value of GPIOs on the Vocore:
List all GPIO, their direction and value
root@OpenWrt:~# cat /sys/kernel/debug/gpio
GPIOs 0-21, platform/10000600.gpio, 10000600.gpio:
 gpio-0   (gpio0               ) in  hi
 gpio-12  (gpio12              ) in  hi
 gpio-13  (gpio13              ) in  hi
 gpio-17  (gpio17              ) in  lo
 gpio-18  (gpio18              ) in  lo
 gpio-19  (gpio19              ) in  lo
 gpio-20  (gpio20              ) in  lo
 gpio-21  (gpio21              ) in  hi
GPIOs 22-27, platform/10000660.gpio, 10000660.gpio:
 gpio-22  (vocore:green:status ) out hi
 gpio-23  (gpio23              ) in  lo
 gpio-24  (gpio24              ) in  lo
 gpio-25  (gpio25              ) in  hi
 gpio-26  (vocore:orange:eth   ) out hi
Confirming state of GPIO0
root@OpenWrt:~# cat /sys/class/gpio/gpio0/direction
in
root@OpenWrt:~# cat /sys/class/gpio/gpio0/value
1
Attempting to set GPIO0 value to 0 (low)
root@OpenWrt:~# echo 0 > /sys/class/gpio/gpio0/value
ash: write error: Operation not permitted
Attempting to set GPIO19 value to 0 (low)
root@OpenWrt:~# echo 0 > /sys/class/gpio/gpio19/value
I've also connected GPIO0 to a circuit powered by the 3.3V pin and a simple button. I've tried both pull down and pull up resistors. But pressing the button does not change the GPIO value. I tried the same thing on GPIO19.
Any ideas on what I'm doing wrong?
Allan
Re: Unable to change GPIO values or directions
Fri Feb 05, 2016 1:50 am
Hi, it you want to change output data, the direction should be out(but not in).
echo out > ..../direction
echo 0 > ..../value
allanmitch
Mon Feb 08, 2016 8:15 pm
Embarrassingly, I discovered that I had wired my breadboard incorrectly. Once I had the connections on the breadboard correctly set, the Vocore worked fine. Now, every time I close the doorbell switch, I get a change in GPIO value.
I wanted to change the input data. The GPIO0 direction was set to 'in' because pressing the doorbell sends a signal to the vocore. I set up the circuit to be pull up, so that when the doorbell was open the value was 0. Now, pressing the doorbell successfully changes the value to 1. When the doorbell switch is released, the value returns to 0.
Well, at least I learned a lot.
Users browsing this forum: No registered users and 93 guests
