No WiFi any more
Posted: Mon Feb 29, 2016 1:05 am
Hey all,
I've just received my VoCore recently and started playing around a bit. With the original firmware (Barrier Breaker) everything seemed to work fine. I could access the AP, I even got an 802.11s mesh WiFi working. Since I wanted to add some custom stuff to the firmware I built a new image off current OpenWRT trunk. I installed it using LuCI, everything seemed to work. It booted up fine. But the WiFi never came online.
I suspected it was my firmware, so I tried all of Vonger's firmware images I could find (I tried vocore.bin, vocore16.bin, vocore.v1.0.bin and vocore.dock2.bin), all of them are Chaos Calmer. Still, the issue persists. From the UART console everything looks fine, as if the WiFi would work, but it never shows up on any other devices.
The only thing different is
Best,
invliD.
iw dev wlan0 scan
root@OpenWrt:/# iw dev wlan0 scan
[ 401.290000] ------------[ cut here ]------------
[ 401.300000] WARNING: at /Volumes/VoCore/openwrt/build_dir/target-mipsel_24kec+dsp_uClibc-0.9.33.2/linux-ramips_rt305x/compat-wireless-2014-05-22/drivers/net/wireless/rt2x00/rt2800lib.c:1092 rt2800_conf_tx+0x3c8/0x494 [rt2800lib]()
[ 401.340000] Modules linked in: rt2800soc rt2800mmio rt2800lib pppoe ppp_async iptable_nat rt2x00soc rt2x00mmio rt2x00lib pppox ppp_generic nf_nat_ipv4 nf_conntrack_ipv4 mmc_spi mac80211 ipt_MASQUERADE cfg80211 xt_time xt_tcpudp xt_state xt_nat xt_multiport xt_mark xt_mac xt_limit xt_id xt_conntrack xt_comment xt_TCPMSS xt_REDIRECT xt_LOG xt_CT slhc of_mmc_spi nf_nat_irc nf_nat_ftp nf_nat nf_defrag_ipv4 nf_conntrack_irc nf_conntrack_ftp iptable_raw iptable_mangle iptable_filter ipt_REJECT ip_tables crc7 crc16 crc_itu_t crc_ccitt compat sg i2c_ralink of_i2c i2c_core ip6t_REJECT ip6table_raw ip6table_mangle ip6table_filter ip6_tables x_tables nf_conntrack_ipv6 nf_conntrack nf_defrag_ipv6 vfat fat ipv6 eeprom_93cx6 arc4 crypto_blkcipher mmc_block usb_storage mmc_core ohci_hcd ehci_platform ehci_hcd sd_mod scsi_mod usbcore nls_base usb_common crypto_hash
[ 401.500000] CPU: 0 PID: 1016 Comm: iw Not tainted 3.10.49 #17
[ 401.510000] Stack : 00000000 00000000 00000000 00000000 802fa366 00000031 80d89698 80ef9d40
802563ec 8029654b 000003f8 802f381c 80d89698 80ef9d40 00000008 0000001c
00000001 80204410 00000003 80172648 80ef3bd8 80ef9d40 80257a44 81b6b774
00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
00000000 00000000 00000000 00000000 00000000 00000000 00000000 81b6b700
[ 401.580000] Call Trace:
[ 401.580000] [<801ad0e0>] show_stack+0x48/0x70
[ 401.590000] [<802147f8>] warn_slowpath_common+0x78/0xa8
[ 401.600000] [<802148b0>] warn_slowpath_null+0x18/0x24
[ 401.610000] [<80ee4078>] rt2800_conf_tx+0x3c8/0x494 [rt2800lib]
[ 401.620000]
[ 401.630000] ---[ end trace be6802745103a251 ]---
Best,
invliD.
