more Ethernet ports
reinhar2
more Ethernet ports
Thu Nov 06, 2014 4:09 pm
Hello there,
I reveived my vocores and am happy like a little child. I didn't order a dock, because I want to build an own dock with some more possibilities. I know the RT5350 is capable of up to 5 ethernet ports. So here my question:
How can I connect more than just one RJ45 plugs?
Re: more Ethernet ports
Sat Nov 08, 2014 4:58 am
VoCore export 2 ethernet port, not the totally 5.
They are P0, P4, you can find it on the pin map. http://vocore.io/wiki/index/id:7
Pyrofer
Thu Nov 13, 2014 8:30 pm
Don't forget the magnetics if you are making your own dock.
You can get RJ45 sockets with magnetics built in but don't forget to hook up the 1.8v too or it won't work.
reinhar2
Tue Nov 18, 2014 8:43 am
Thank you very much! Yeah. I know about the Ethernet specifications. So I won't forget it.
SteeevO
Thu Aug 27, 2015 12:18 am
does anyone have en example of the magnetics?
I'm unfamiliar with this.
Thankyou
User avatar
Jefferynege
more Ethernet ports
Thu Oct 22, 2015 2:26 pm
At the moment i do not really mind if its sata 300...i want a cheap controller card which will surely work with 6-8 sata ports..
What about dell perc cards?
Users browsing this forum: No registered users and 36 guests
