Unbrick vocore
Posted: Sat Mar 05, 2016 11:44 pm
by extraman
Hi there
I have 1 bricked vocore and I would like some directions in order to put it back to work. It seems to boot but not all the way through...
The only thing I did was to setup wireless to my AP through luci, and afterwards vocore doesn't boot properly.
I tried with serial connection and terminal but I cannot press x on boot start, and it seems that nothing I pressed will go through the serial connection to vocore.
Here is the last lines of the console output. Can anyone help me?
[ 15.200000] Backport generated by backports.git backports-20140320-37-g5c33da0
[ 15.230000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 15.310000] xt_time: kernel timezone is -0000
[ 15.360000] cfg80211: Calling CRDA to update world regulatory domain
[ 15.370000] cfg80211: World regulatory domain updated:
[ 15.380000] cfg80211: DFS Master region: unset
[ 15.390000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[ 15.410000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.430000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.440000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.460000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.480000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 15.490000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[ 15.510000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[ 15.520000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[ 15.630000] PPP generic driver version 2.4.2
[ 15.640000] NET: Registered protocol family 24
[ 15.700000] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5350, rev 0500 detected
[ 15.720000] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5350 detected
procd: - init complete -
[ 27.460000] device eth0.1 entered promiscuous mode
[ 27.470000] device eth0 entered promiscuous mode
[ 27.480000] br-lan: port 1(eth0.1) entered forwarding state
[ 27.500000] br-lan: port 1(eth0.1) entered forwarding state
[ 29.500000] br-lan: port 1(eth0.1) entered forwarding state
Re: Unbrick vocore
Posted: Sun Mar 06, 2016 12:50 am
14.07 luci has issue.
Once you set it, the wireless will fail.
Please check vocore.io/wiki, just reset the wireless setting or firmware, everything will back to normal.
Re: Unbrick vocore
Posted: Sun Mar 06, 2016 1:47 am
by extraman
Can you guide me a bit more?
I've seen the wiki but didn't come to any conclusions.
There's a description of 4 ways to upload a new firmware, but since I cannot access serial console how can I do it?
Thanks
