In the blog VoCore: SPI & MicroSD 12 there is a list of patches. Item number 4 says:
Change dts flash partition to fit 16MB flash.(keep the line if you are using 8MB version vocore)
I was not aware that there are two versions? Which one is the "normal" one that is delivered?
8 or 16MB?
- Pyrofer
Re: 8 or 16MB?
Assuming I just flashed my "final" VoCore with the same image I made for the Alpha boards, I assume that means I am only seeing half the flash space then?
Is there a simple command line fix or do I have to remake an image and sysupgrade it again...?
- drasko
Re: 8 or 16MB?
What is the state now - the boards that are in the store are they 8MB or 16MB?
- Peter H
Users browsing this forum: No registered users and 49 guests
