Doesn't boot automatically
jmendeth
Wed Dec 10, 2014 7:03 pm
I've been playing with the VoCore, and when I built and uploaded my sysupgrade image, it doesn't start.
This is everything it prints:
Version: May 30 2014 20:52:36
Press 'x' to console...
Booting image at bc050000 .
   Image Name:   MIPS OpenWrt Linux-3.10.49
   Created:      2014-12-10  13:02:26 UTC
   Data Size:    1006262 Bytes = 982.7 kB
   Load Address: 80000000
   Entry Point:  80000000
   Load Kernel:  ................
   Verifying Checksum ... OK
[    0.000000] Linux version 3.10.49 (xavier@xavier-pad) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r43321) ) #1 Wed Dec 10 14:02:19 CET 2014
[    0.000000] SoC Type: Ralink RT5350 id:1 rev:3
[    0.000000] CPU revision is: 0001964c (MIPS 24KEc)
[    0.000000] MIPS: machine is VoCore
[    0.000000]  memory: 02000000 @ 00000000 (usable)
However, if I press "x" and manually tell U-boot to boot, it starts correctly:
VoCore> bootm bc050000
[    0.000000] Zone ranges:
[    0.000000]   Normal   [mem 0x00000000-0x01ffffff]
[    0.000000]   node   0: [mem 0x00000000-0x01ffffff]
[    0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
[    0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 8128
[    0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
[    0.000000] PID hash table entries: 128 (order: -3, 512 bytes)
[    0.000000] Dentry cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Inode-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000000] Writing ErrCtl register=00042c30
[    0.000000] Readback ErrCtl register=00042c30
[    0.000000] Memory: 29348k/32768k available (2162k kernel code, 3420k reserved, 557k data, 156k init, 0k highmem)
[    0.000000] NR_IRQS:256
[    0.000000] CPU Clock: 360MHz
[    0.000000] Calibrating delay loop... 239.61 BogoMIPS (lpj=1198080)
[    0.070000] pid_max: default: 32768 minimum: 301
[    0.070000] Mount-cache hash table entries: 512
[    0.080000] pinctrl core: initialized pinctrl subsystem
[    0.090000] NET: Registered protocol family 16
[    0.140000] bio: create slab <bio-0> at 0
[    0.150000] rt2880_gpio 10000600.gpio: registering 22 gpios
[    0.160000] rt2880_gpio 10000600.gpio: registering 22 irq handlers
[    0.170000] rt2880_gpio 10000660.gpio: registering 6 gpios
[    0.180000] rt2880_gpio 10000660.gpio: registering 6 irq handlers
[    0.190000] Switching to clocksource MIPS
[    0.200000] NET: Registered protocol family 2
[    0.210000] TCP established hash table entries: 512 (order: 0, 4096 bytes)
[    0.230000] TCP bind hash table entries: 512 (order: -1, 2048 bytes)
[    0.240000] TCP: Hash tables configured (established 512 bind 512)
[    0.250000] TCP: reno registered
[    0.260000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.270000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.280000] NET: Registered protocol family 1
[    0.290000] rt-timer 10000100.timer: maximum frequncy is 7324Hz
[    0.350000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.360000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[    0.380000] msgmni has been set to 57
[    0.390000] io scheduler noop registered
[    0.400000] io scheduler deadline registered (default)
[    0.420000] gpio-export gpio-export.4: 17 gpio(s) exported
[    0.440000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
[    0.450000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20) is a 16550A
[    0.470000] console [ttyS0] enabled, bootconsole disabled
[    0.500000] m25p80 spi32766.0: found w25q128, expected s25fl064k
[    0.510000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[    0.520000] 4 ofpart partitions found on MTD device spi32766.0
[    0.530000] Creating 4 MTD partitions on "spi32766.0":
[    0.550000] 0x000000000000-0x000000030000 : "uboot"
[    0.560000] 0x000000030000-0x000000040000 : "uboot-env"
[    0.570000] 0x000000040000-0x000000050000 : "factory"
[    0.590000] 0x000000050000-0x000001000000 : "firmware"
[    0.600000] 0x000000145af6-0x000001000000 : "rootfs"
[    0.610000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
[    0.640000] mtd: device 4 (rootfs) set to be root filesystem
[    0.650000] mtd: partition "rootfs_data" created automatically, ofs=0x330000, len=0xcd0000
[    0.670000] 0x000000330000-0x000001000000 : "rootfs_data"
[    0.700000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[    0.710000] rt3xxx-usbphy usbphy.3: loaded
[    0.720000] rt2880_wdt 10000120.watchdog: Initialized
[    0.730000] TCP: cubic registered
[    0.740000] NET: Registered protocol family 17
[    0.750000] 8021q: 802.1Q VLAN Support v1.8
[    0.780000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
[    0.800000] Freeing unused kernel memory: 156K (802a9000 - 802d0000)
procd: Console is alive
procd: - watchdog -
[    6.800000] usbcore: registered new interface driver usbfs
[    6.810000] usbcore: registered new interface driver hub
[    6.820000] usbcore: registered new device driver usb
[    6.840000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    6.860000] ehci-platform: EHCI generic platform driver
[    7.070000] rt3xxx-usbphy usbphy.3: remote usb device wakeup disabled
[    7.080000] rt3xxx-usbphy usbphy.3: UTMI 16bit 30MHz
[    7.090000] ehci-platform 101c0000.ehci: EHCI Host Controller
[    7.100000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[    7.120000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[    7.150000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[    7.160000] hub 1-0:1.0: USB hub found
[    7.170000] hub 1-0:1.0: 1 port detected
[    7.180000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    7.190000] ohci-platform 101c1000.ohci: Generic Platform OHCI Controller
[    7.210000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[    7.220000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[    7.290000] hub 2-0:1.0: USB hub found
[    7.300000] hub 2-0:1.0: 1 port detected
[    7.310000] leds-gpio gpio-leds.5: pins are not configured from the driver
procd: - preinit -
[    8.430000] rt305x-esw 10110000.esw: link changed 0x00
jffs2 is ready
jffs2 is ready
[   12.500000] jffs2: notice: (313) jffs2_build_xattr_subsystem: complete building xattr subsystem, 17 of xdatum (0 unchecked, 16 orphan) and 23 of xref (0 dead, 16 orp.
switching to overlay
procd: - early -
procd: - watchdog -
procd: - ubus -
procd: - init -
[   15.190000] NET: Registered protocol family 10
[   15.210000] nf_conntrack version 0.5.0 (461 buckets, 1844 max)
[   15.240000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[   15.280000] i2c-ralink 10000900.i2c: loaded
[   15.300000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
[   15.320000] Backport generated by backports.git backports-20140320-37-g5c33da0
[   15.340000] ip_tables: (C) 2000-2006 Netfilter Core Team
[   15.420000] xt_time: kernel timezone is -0000
[   15.470000] cfg80211: Calling CRDA to update world regulatory domain
[   15.480000] cfg80211: World regulatory domain updated:
[   15.490000] cfg80211:  DFS Master region: unset
[   15.500000] cfg80211:   (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
[   15.520000] cfg80211:   (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.540000] cfg80211:   (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
[   15.550000] cfg80211:   (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
[   15.570000] cfg80211:   (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
[   15.590000] cfg80211:   (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   15.600000] cfg80211:   (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
[   15.620000] cfg80211:   (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
[   15.630000] cfg80211:   (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
[   15.750000] PPP generic driver version 2.4.2
[   15.760000] NET: Registered protocol family 24
[   15.820000] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5350, rev 0500 detected
[   15.840000] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5350 detected
procd: - init complete -
Does anybody know what's happening?
PS: I did the fix on VOCORE.dts before building.
Re: Doesn't boot automatically
Fri Dec 12, 2014 12:54 pm
do you mean it stopped here?
jmendeth
Sat Dec 13, 2014 11:53 am
That's correct, this is the last message it prints (when I let it boot).
jmendeth
Sat Dec 13, 2014 11:55 am
After printing this, it won't do anything else.
I have to remove the power and start it again.
Sun Dec 14, 2014 12:23 pm
First time meet such problem.
I guess it is initrd problem. Maybe check Linux kernel code to find out what is happening there. Do you modify any factory setting or initrd parameters?
jmendeth
Sun Dec 14, 2014 4:05 pm
This is what I did:
1. Downloaded OpenWRT 14.07 directly (without Git)
2. Modified VOCORE.dts as said in the wiki
3. make menuconfig
4. make
5. Uploaded sysupgrade image via LuCI.
jmendeth
Sun Dec 14, 2014 5:32 pm
I did the steps again (downloaded everything again, etc.) and it's working now...
Weird.
Thanks for the help anyway. :)
Users browsing this forum: No registered users and 329 guests
