I'm sure i'm not alone who want to make vocore become wifi client in their home network. But if you miss something you lost connection to vocore at all.
Now I write several steps to config wificlient on vocore and i hope it will help someone.
1. Let's see default config. First you should ssh you vocore. Then edit /etc/config/wireless in the way like that:
config wifi-device 'radio0'
option type 'mac80211'
option channel 'auto'
option hwmode '11g'
option path '10180000.wmac'
option txpower '20'
option htmode 'HT40'
option country 'RU'
config wifi-iface
option device 'radio0'
option network 'wlan0' # name of new interface
option mode 'sta' # client mode
option ssid 'daxwifi2' # ssid of you home network
option encryption 'psk2'
option key 'password' # change to tou wifi password
Then add to /etc/config/network
config interface wlan0
option proto 'dhcp'
And finally
/etc/init.d/network restart
if you do everything right vocore connect to your homenet
Wifi client microHOWTO
- silviop
Re: Wifi client microHOWTO
--But if you miss something you lost connection to vocore at all
I suppose that there is a safe boot default pin in vocore
http://wiki.openwrt.org/doc/howto/generic.failsafe
but i don't' find it in wiki.
- AR560
How about no?
You can also connect via uart tty terminal
Look at 6 page:
http://vonger.cn/upload/vocore.manual.pdf
How about no?
Look at 6 page:
- Daxer
Yes, you are right. I mean you lost network connection. UART will work.
- Peter H
The Ethernet interface is configured in the WAN zone by default so you can't use it to manage the VoCore. I recommend moving it to the LAN zone first (and check you can connect by SSH and HTTP) before you risk playing with the WiFi settings.
If you have established a serial connection, that gives you another option to get back into the VoCore if you break the WiFi configuration, but I found it far easier to get the WiFi configuration working through the web interface.
- contractorwolf
peter h - can you explain how to best switch the Ethernet Interface from WAN to LAN?
- Peter H
The way I found easiest was to establish a WiFi connection so I could log into the LuCI web interface, then use the Network menu to open the Firewall configuration page. As standard there are two zones - WAN and LAN. Click the Edit link next to the WAN zone and un-tick the LAN interface (eth0.1) to remove it from this zone. Then edit the LAN zone and tick the LAN interface (eth0.1) to add it to the LAN zone. You should then be able to connect to the web interface and establish SSH connections to the Ethernet interface. Once you've achieved that it's safe to play with the WiFi configuration to change it from AP mode to STA mode so it can associate with your home WiFi network.
pcnate - Posts: 3
It took me a while to figure it out on my WPA2 network after I locked myself out and had to resort to a usb to serial connection. I think I screwed up a few wireless settings and couldn't get anything working. What worked was to do the following:
Reset the wireless config I screwed up:
At this point you could connect to the AP after restarting the network like this:
Instead, I wanted my VoCore on the network so I changed the /etc/config/wireless configuration to the following:
wifi detect > /etc/config/wireless
config wifi-device radio0
option type mac80211
option channel 11
option hwmode 11g
option htmode HT20
config wifi-iface
option device radio0
option network lan
option mode sta
option ssid mynetwork
option encryption psk2
option key 'mypassword'
- hdokes
Is more than one SSID wifi network configuration in a client mode allowable? In the event the unit 'roams' can two networks for wifi be configured in a client mode with the ability of the vocore to auto connect to the one it can reach at the moment?
