Installation of kmod modules
Posted: Mon Dec 22, 2014 2:30 pm
I would like to use the firmware released by Vonger, which allows to use the mmc card, but want to compile and install some additional kernel modules.
I understood from the text appearing at the login that the OpenWRT revision is r42583.
Therefore I checked out the OpenWRT sources from git and compiled them (all went fine):
git clone git://git.openwrt.org/openwrt.git
git checkout 7dd11cd2c8b01e57d0da41247a8c898f9faabe12
The number from the checkout I deduced from the git log command which showed:
commit 7dd11cd2c8b01e57d0da41247a8c898f9faabe12
Author: hauke <hauke@3c298f89-4303-0410-b956-a3cf2f4a3e73>
Date: Tue Sep 16 21:39:24 2014 +0000
kernel: add missing config option
This missing option was found by the build bots.
Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
git-svn-id: svn://svn.openwrt.org/openwrt/trunk@42583 3c298f89-4303-0410-b956-a3cf2f4a3e73
When I now take the kernel modules of my compilation I anyway get dependency problems and the modules do not load. For example when I try to load the compiled kmod-fs-ext4 I get (I put the packages compiled by me on my internal web server on my router (of course also OpenWRT
opkg install kmod-fs-ext4
Installing kmod-fs-ext4 (3.14.18-1) to root...
Downloading http://192.168.0.1/public/vocore/kmod-f ... _24kec.ipk.
Collected errors:
* satisfy_dependencies_for: Cannot satisfy the following dependencies for kmod-fs-ext4:
* kernel (= 3.14.18-1-0fb3f9bd9caf703f5be8cdca365b7bfe) * kernel (= 3.14.18-1-0fb3f9bd9caf703f5be8cdca365b7bfe) * kernel (= 3.14.18-1-0fb3f9bd9caf703f5be8cdca365b7bfe) *
* opkg_install_cmd: Cannot install package kmod-fs-ext4.
Did I check out the wrong version of OpenWRT? How do I check out the correct one (from git)?
Any other suggestion what I am doing wrong, or what I need to do to compile successfully kernel modules for that particular firmware of Vonger? (I know, I could try to flash my own created firmware image... but I wanted to go with minimal risk, given that the firmware of Vonger works...)
Many thanks for any hint!
Collected errors:
