Daisy chain using internal ethernet switch?
Posted: Sun Nov 09, 2014 4:27 pm
Does someone know if in standard vocore.dts P0 and P4 are ethernet packet switched ports?
What i know of rt5350 is that it has two rx description rigs, so you can have two ethX (wan/lan for example).
If i want make a daisy chain of vocore i need or to brigdge eth0<->eth1(in linux) or use hardware ethernet switch to switch packet from P0<->P4 trasparently.
Use hardware switch is more efficent if possible but i m not shure how it work.
