First time power up - no image?
Posted: Thu Dec 25, 2014 2:50 pm
by fanl
Hello!
My Vocore+dock has just arrived and I didn't find how to interact with it.
- I have powered on using the micro-USB
- No new wireless SSID appears at the range after powering on
- No IP is acquired using DHCP on the host PC when connecting a cable to the the Vocore's physical ethernet port.
How should I proceed? Is there any PDF for the firsts steps?
Thanks in advance!
Re: First time power up - no image?
Posted: Fri Dec 26, 2014 11:57 am
by Greenwire-Elektronik
Do you see any LEDs on the LAN dock blinking? If you are sure your power supply is good (e.g. you are using a cellphone loading power supply), you might consider connecting the delivered usb stick to your vocore - what are your cabling/soldering skills?
Rgds
Jonas
Posted: Sat Dec 27, 2014 2:35 am
by fanl
My cable and power supply setup is fine. What I am getting is three leds being kept on, they are the two of the rj45 and the VoCore main board green led. There is no blinking at all, not even when I connect or disconnect Ethernet cable.
I can solder fine, but got no tools until January 5th.
Any ideas?
Thanks again.
Posted: Sat Dec 27, 2014 8:35 am
you could connect via LAN and give your host PC a IP in the 192.168.61.x subnet (except .1 - it is the vocore's address). You might reach it per ssh.
You are sure with the SSID? I had also some problems, figured out my Laptop was making trouble.
Rgds
Posted: Sat Dec 27, 2014 4:58 pm
by fanl
Well, I've got no answer on pinging 192.168.61.1 using the LAN port, nor the RJ45 leds blinks when pinging. That's strange.
Is there any other thing I should try before using the UART port ?
Posted: Sun Dec 28, 2014 12:40 pm
Please try to connect with UART, and read the log from serial port.
To see what is happening there. Maybe vocore.io/wiki will help you connect it with UART.
Normally, the wifi will work well and once connect it to power, it will show VoCore AP in 1 minute.
Sometimes if your power supply is not that stable, it will go into infinite reboot loop, you have to connect to UART to find out what is happening inside.
Posted: Wed Jan 07, 2015 5:01 pm
by fanl
Strange, the problem is gone after I removed the VoCore from a 3D printed case or I had missunderstood the problem from the begining. Well, the fact is that it is working fine!
Thank you all for your attention !
