Can anyone help please?
I compiled the latest firmware following the instructions here: http://vonger.cn/?p=412
Then I installed the update using the Luci interface as per the instructions here: http://vocore.io/wiki/index/id:14 (option 1).
I ticked the box to save settings however after the installation I am unable to log in.
SSH rejects my password (vocore no longer works, neither does a blank password).
Web access directs to /cgi-bin/luci and then fails (unable to connect error).
Why did the upgrade change the login password? Does anyone know what the new password is and how I can get back in?
Many thanks for any info.
Unable to log in following firmware upgrade..
- ricsto
- Greenwire-Elektronik
Re: Unable to log in following firmware upgrade..
How did you update?
Try to connect via telnet and then set the password via passwd.
- Peter H
If connect a serial client such as PuTTY via the serial UART then it will connect you to the console as root - no password required. This should enable you to reset the root password or use dmesg, logread etc to find out what other problems are stopping you from connecting via the network.
Users browsing this forum: No registered users and 6 guests
