Temperature
Posted: Wed Nov 12, 2014 12:38 pm
by pkedvessy
What's the normal temperature of the module?
I'm just recieved it (with dock) and I feel that it is quite hot while it is idling.
Re: Temperature
Posted: Thu Nov 13, 2014 4:06 am
That is normal, summer 31C, the surface of it is about 70+. That time, I keep it run for six days with full speed, it still works normal, no damage to the chip, but just careful to avoid be hurt..
Re: Temperature
Posted: Thu Nov 13, 2014 2:48 pm
by pkedvessy
Is there any command to check the core temperature?
Re: Temperature
Posted: Thu Nov 13, 2014 8:34 pm
by Pyrofer
I run mine all the time under high load and yes, it gets hot but it seems to be ok.
If you can find a small heat sink off an old piece of equipment and some thermal paste you can reduce the temp of the chip a LOT.
Look at the support chips on an old PC motherboard for small heatsinks but beware the chip antenna, make sure whatever you attach doesn't overhang or touch it.
