i've ordered a vocore with dock already soldered.
I can access the vocore per wlan and then start configuring with luci or per commandline.
But i don't get ethernet working.
i've tried to simply udhcpc eth0 or an ifconfig eth0 ipaddress/mask
Then i've tried with luci to put the adapter 4 (that shows me the switch) into the vlan and then bridge eth0 with eth0.1
But same here, no chance to get an ip or communicate with a static one.
is there something simple i forget?
The thing ist, i can see with dmesg link changes when i plug in the cable or pull it out so i think the main thing is running.
hope someone can help
regards
Vocore Dock, Ethernet not working
- celevra
- Greenwire-Elektronik
Re: Vocore Dock, Ethernet not working
Have you (without reconfiguring) tried to ping 192.168.61.1 ? This is the default address of a fabric-new VoCore. Do you see LEDs working on the Ethernet Port?
- celevra
you mean to access the vocore per ethernet cable through 192.168.61.1 and not per wlan?
no i haven't tried that, i though they where independet.
I will compile the firmware, flash it and give it a try
--- Edit
tried that, it is only accessible per WLAN, not per Ethernet Port.
LED's are flashing
--- Edit
LED's are flashing
- celevra
tried that, it's not working, it is only per wlan accessible.
LED's are flashing
LED's are flashing
- celevra
tried that, it is only accessible per WLAN not per Ethernet Port.
LED's are flashing.
LED's are flashing.
- celevra
tried that. It is only accessible per WLAN not per Ethernet Port.
LED's are flashing.
LED's are flashing.
