I have built a new firmware of my project, when update it in the board. the usb port can't work. once I insert a usb Cam to the board.
the kernel message show below:
[ 56.350000] usb 1-1: device descriptor read/64, error -145
[ 72.080000] usb 1-1: device descriptor read/64, error -145
[ 72.350000] usb 1-1: new high-speed USB device number 4 using ehci-platform
[ 82.840000] usb 1-1: device not accepting address 4, error -145
[ 82.980000] usb 1-1: new high-speed USB device number 5 using ehci-platform
[ 93.490000] usb 1-1: device not accepting address 5, error -145
connected timeout. did I miss some driver of USB?
who can help me?
USB error
Re: USB error
I get this error when I develop VoCore. I confused D+, D-. Maybe you are some issue.
- superboy007489
Re: USB error
Vonger wrote:I get this error when I develop VoCore. I confused D+, D-. Maybe you are some issue.
Hi vonger:
I don't think it's result in D+,D-. cause I have read the blog "MJPG Camera" , and try the full image from the link, the board works wondfully!
and I have checked the drivers you listed in it. all of them are included. So where is the difference between your image and what I have built?
- superboy007489
- superboy007489
Re: USB error
Hi vonger:
I found the usb drivers were not insmod successfully?
when I insmod the usb driver manually, kernel shows
kmod: failed to insert usbcore.ko
usbcore: exports duplicate symbol __usb_get_extra_descriptor ( owned by kernel)
Re: USB error
usbcore driver already in VoCore.
That should be other usb driver issue.
Make sure every dependency driver you have installed.
Users browsing this forum: No registered users and 61 guests
