Mistakes after repairing of VoCore
1kvi1
Sat Feb 07, 2015 9:46 am
Hi, all!
Please help me with my troubles.
I am try to use uart cable and information from this link:
http://vonger.cn/?p=780
After soldering cable - I start VoCore and broke it.
Main reason - I used old information, but it marked same as my device - VoCore V.1.0
So I bought some parts at market and repaired VoCore.
Now my VoCore+Dock can not start.
Please check log's:
How I can find reason for this troubles?
How I can test SDRAM?
I try to find memtest in U-Boot but fail.
PS: Please remove wrong information from website.
Any ideas?
    Version: May 30 2014 20:52:36
    Press 'x' to console...
    Booting image at bc050000 .
    Image Name: MIPS OpenWrt Linux-3.14.18
    Created: 2014-09-24 3:19:02 UTC
    Data Size: 1049951 Bytes = 1 MB
    Load Address: 80000000
    Entry Point: 80000000
    Load Kernel: .................
    Verifying Checksum ... OK
    [ 0.000000] Linux version 3.14.18 (vonger@Vongers-MacBook-Pro.local) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r42586) ) #15 Wed Sep 24 11:18:53 CST 2014
    [ 0.000000] SoC Type: Ralink RT5350 id:1 rev:3
    [ 0.000000] bootconsole [early0] enabled
    [ 0.000000] CPU0 revision is: 0001964c (MIPS 24KEc)
    [ 0.000000] MIPS: machine is VoCore
    [ 0.000000] Determined physical RAM map:
    [ 0.000000] memory: 01000000 @ 00000000 (usable)
    [ 0.000000] Initrd not found or empty - disabling initrd
    [ 0.000000] Zone ranges:
    [ 0.000000] Normal [mem 0x00000000-0x00ffffff]
    [ 0.000000] Movable zone start for each node
    [ 0.000000] Early memory node ranges
    [ 0.000000] node 0: [mem 0x00000000-0x00ffffff]
    [ 0.000000] Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
    [ 0.000000] Primary data cache 16kB, 4-way, VIPT, no aliases, linesize 32 bytes
    [ 0.000000] Built 1 zonelists in Zone order, mobility grouping off. Total pages: 4064
    [ 0.000000] Kernel command line: console=ttyS0,57600 rootfstype=squashfs,jffs2
    [ 0.000000] PID hash table entries: 64 (order: -4, 256 bytes)
    [ 0.000000] Dentry cache hash table entries: 2048 (order: 1, 8192 bytes)
    [ 0.000000] Inode-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.000000] Writing ErrCtl register=00067e0e
    [ 0.000000] Readback ErrCtl register=00067e0e
    [ 0.000000] Memory: 12968K/16384K available (2284K kernel code, 119K rwdata, 456K rodata, 140K init, 180K bss, 3416K reserved)
    [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [ 0.000000] NR_IRQS:256
    [ 0.000000] CPU Clock: 360MHz
    [ 0.000000] systick: running - mult: 214748, shift: 32
    [ 0.000000] genirq: Flags mismatch irq 7. 00014600 (timer) vs. 00014600 (systick)
    [ 0.010000] Calibrating delay loop... 479.23 BogoMIPS (lpj=2396160)
    [ 0.070000] pid_max: default: 32768 minimum: 301
    [ 0.070000] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.080000] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.090000] pinctrl core: initialized pinctrl subsystem
    [ 0.090000] NET: Registered protocol family 16
    [ 0.120000] bio: create slab <bio-0> at 0
    [ 0.120000] rt2880_gpio 10000600.gpio: registering 22 gpios
    [ 0.130000] rt2880_gpio 10000600.gpio: registering 22 irq handlers
    [ 0.130000] rt2880_gpio 10000660.gpio: registering 6 gpios
    [ 0.140000] rt2880_gpio 10000660.gpio: registering 6 irq handlers
    [ 0.150000] Switched to clocksource systick
    [ 0.150000] NET: Registered protocol family 2
    [ 0.170000] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.190000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
    [ 0.190000] TCP: Hash tables configured (established 1024 bind 1024)
    [ 0.210000] TCP: reno registered
    [ 0.220000] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.220000] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [ 0.240000] NET: Registered protocol family 1
    [ 0.250000] rt-timer 10000100.timer: maximum frequency is 7324Hz
    [ 0.270000] futex hash table entries: 256 (order: -1, 3072 bytes)
    [ 0.330000] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [ 0.330000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
    [ 0.360000] msgmni has been set to 25
    [ 0.360000] io scheduler noop registered
    [ 0.380000] io scheduler deadline registered (default)
    [ 0.400000] gpio-export gpio-export.4: 17 gpio(s) exported
    [ 0.420000] Serial: 8250/16550 driver, 2 ports, IRQ sharing disabled
    [ 0.430000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 20, base_baud = 2500000) is a 16550A
    [ 0.450000] console [ttyS0] enabled
    [ 0.470000] bootconsole [early0] disabled
    [ 0.490000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
    [ 0.510000] m25p80 spi32766.0: unique id: D2621044DB2B162D
    [ 0.510000] 4 ofpart partitions found on MTD device spi32766.0
    [ 0.530000] Creating 4 MTD partitions on "spi32766.0":
    [ 0.530000] 0x000000000000-0x000000030000 : "uboot"
    [ 0.550000] 0x000000030000-0x000000040000 : "uboot-env"
    [ 0.570000] 0x000000040000-0x000000050000 : "factory"
    [ 0.570000] 0x000000050000-0x000001000000 : "firmware"
    [ 0.600000] 0x00000015059f-0x000001000000 : "rootfs"
    [ 0.600000] mtd: partition "rootfs" must either start or end on erase block boundary or be smaller than an erase block -- forcing read-only
    [ 0.630000] mtd: device 4 (rootfs) set to be root filesystem
    [ 0.650000] mtd: partition "rootfs_data" created automatically, ofs=0x3d0000, len=0xc30000
    [ 0.670000] 0x0000003d0000-0x000001000000 : "rootfs_data"
    [ 0.690000] eth0: done loading
    [ 0.690000] rt3xxx-usbphy usbphy.3: loaded
    [ 0.710000] rt2880_wdt 10000120.watchdog: Initialized
    [ 0.710000] TCP: cubic registered
    [ 0.730000] NET: Registered protocol family 17
    [ 0.730000] 8021q: 802.1Q VLAN Support v1.8
    [ 0.760000] VFS: Mounted root (squashfs filesystem) readonly on device 31:4.
    [ 0.780000] Freeing unused kernel memory: 140K (802cd000 - 802f0000)
    procd: Console is alive
    procd: - watchdog -
    [ 6.610000] usbcore: registered new interface driver usbfs
    [ 6.630000] usbcore: registered new interface driver hub
    [ 6.640000] usbcore: registered new device driver usb
    [ 6.660000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [ 6.680000] ehci-platform: EHCI generic platform driver
    [ 7.080000] rt3xxx-usbphy usbphy.3: remote usb device wakeup disabled
    [ 7.100000] rt3xxx-usbphy usbphy.3: UTMI 16bit 30MHz
    [ 7.110000] ehci-platform 101c0000.ehci: EHCI Host Controller
    [ 7.130000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
    [ 7.130000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
    [ 7.170000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
    [ 7.190000] hub 1-0:1.0: USB hub found
    [ 7.190000] hub 1-0:1.0: 1 port detected
    [ 7.210000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [ 7.230000] ohci-platform: OHCI generic platform driver
    [ 7.230000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
    [ 7.250000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
    [ 7.270000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
    [ 7.330000] hub 2-0:1.0: USB hub found
    [ 7.340000] hub 2-0:1.0: 1 port detected
    procd: - preinit -
    [ 8.680000] rt305x-esw 10110000.esw: link changed 0x00
    [ 9.020000] random: mktemp urandom read with 77 bits of entropy available
    jffs2 is ready
    jffs2 is ready
    [ 12.610000] jffs2: notice: (315) jffs2_build_xattr_subsystem: complete building xattr subsystem, 1 of xdatum (0 unchecked, 0 orphan) and 7 of xref (0 dead, 0 orphan) found.
    switching to overlay
    procd: - early -
    procd: - watchdog -
    procd: - ubus -
    procd: - init -
    [ 16.000000] NET: Registered protocol family 10
    [ 16.020000] tun: Universal TUN/TAP device driver, 1.6
    [ 16.020000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
    [ 16.050000] nf_conntrack version 0.5.0 (204 buckets, 816 max)
    [ 16.070000] ip6_tables: (C) 2000-2006 Netfilter Core Team
    [ 16.110000] i2c-ralink 10000900.i2c: loaded
    [ 16.120000] Loading modules backported from Linux version master-2014-05-22-0-gf2032ea
    [ 16.140000] Backport generated by backports.git backports-20140320-37-g5c33da0
    [ 16.160000] ip_tables: (C) 2000-2006 Netfilter Core Team
    [ 16.250000] xt_time: kernel timezone is -0000
    [ 16.390000] cfg80211: Calling CRDA to update world regulatory domain
    [ 16.420000] cfg80211: World regulatory domain updated:
    [ 16.420000] cfg80211: DFS Master region: unset
    [ 16.440000] cfg80211: (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp), (dfs_cac_time)
    [ 16.460000] cfg80211: (2402000 KHz - 2472000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [ 16.460000] cfg80211: (2457000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm), (N/A)
    [ 16.490000] cfg80211: (2474000 KHz - 2494000 KHz @ 20000 KHz), (N/A, 2000 mBm), (N/A)
    [ 16.500000] cfg80211: (5170000 KHz - 5250000 KHz @ 160000 KHz), (N/A, 2000 mBm), (N/A)
    [ 16.520000] cfg80211: (5250000 KHz - 5330000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
    [ 16.540000] cfg80211: (5490000 KHz - 5730000 KHz @ 160000 KHz), (N/A, 2000 mBm), (0 s)
    [ 16.540000] cfg80211: (5735000 KHz - 5835000 KHz @ 80000 KHz), (N/A, 2000 mBm), (N/A)
    [ 16.540000] cfg80211: (57240000 KHz - 63720000 KHz @ 2160000 KHz), (N/A, 0 mBm), (N/A)
    [ 17.250000] PPP generic driver version 2.4.2
    [ 17.270000] NET: Registered protocol family 24
    [ 18.700000] ieee80211 phy0: rt2x00_set_rt: Info - RT chipset 5350, rev 0500 detected
    [ 18.730000] ieee80211 phy0: rt2x00_set_rf: Info - RF chipset 5350 detected
    [ 19.170000] random: nonblocking pool is initialized
    [ 33.950000] device eth0.1 entered promiscuous mode
    [ 33.950000] device eth0 entered promiscuous mode
    [ 33.990000] br-lan: port 1(eth0.1) entered forwarding state
    [ 34.000000] br-lan: port 1(eth0.1) entered forwarding state
    [ 36.000000] br-lan: port 1(eth0.1) entered forwarding state
    procd: - init complete -
    [ 47.420000] IPv6: ADDRCONF(NETDEV_UP): wlan0-1: link is not ready
    [ 50.220000] device wlan0-1 entered promiscuous mode
    [ 100.330000] fw3 invoked oom-killer: gfp_mask=0x201da, order=0, oom_score_adj=0
    [ 100.330000] CPU: 0 PID: 918 Comm: fw3 Not tainted 3.14.18 #15
    [ 100.350000] Stack : 00000000 00000000 00000000 00000000 8031ad2e 00000031 80429998 00000000
    80279824 802bc697 00000396 8031399c 80429998 00000000 802bc048 802bc164
    00000000 80223678 00000000 8018ed58 00000006 00000020 8027c9b4 80f4fbb4
    00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    00000000 00000000 00000000 00000000 00000000 00000000 00000000 80f4fb40
    [ 100.420000] Call Trace:
    [ 100.420000] [<801caf80>] show_stack+0x48/0x70
    [ 100.440000] [<80222c9c>] dump_header.isra.17+0x4c/0x13c
    [ 100.440000] [<8016f938>] oom_kill_process+0xc8/0x3c8
    [ 100.440000] [<801708b4>] out_of_memory+0x2f0/0x328
    [ 100.440000] [<80026530>] __alloc_pages_nodemask+0x684/0x6e8
    [ 100.440000] [<800d9b20>] filemap_fault+0x214/0x3e4
    [ 100.440000] [<80030934>] __do_fault+0xd0/0x4fc
    [ 100.440000] [<800f65a8>] handle_mm_fault+0x220/0x98c
    [ 100.440000] [<80031108>] __do_page_fault+0x168/0x3c0
    [ 100.440000] [<80004420>] ret_from_exception+0x0/0x10
    [ 100.440000]
    [ 100.440000] Mem-Info:
    [ 100.440000] Normal per-cpu:
    [ 100.440000] CPU 0: hi: 0, btch: 1 usd: 0
    [ 100.440000] active_anon:488 inactive_anon:5 isolated_anon:0
    [ 100.440000] active_file:134 inactive_file:189 isolated_file:0
    [ 100.440000] unevictable:0 dirty:0 writeback:0 unstable:0
    [ 100.440000] free:113 slab_reclaimable:118 slab_unreclaimable:1131
    [ 100.440000] mapped:20 shmem:9 pagetables:60 bounce:0
    [ 100.440000] free_cma:0
    [ 100.440000] Normal free:452kB min:452kB low:564kB high:676kB active_anon:1952kB inactive_anon:20kB active_file:536kB inactive_file:756kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:16384kB managed:13108kB mlocked:0kB dirty:0kB writeback:0kB mapped:80kB shmem:36kB slab_reclaimable:472kB slab_unreclaimable:4524kB kernel_stack:288kB pagetables:240kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:2042 all_unreclaimable? yes
    [ 100.440000] lowmem_reserve[]: 0 0
    [ 100.440000] Normal: 1*4kB (R) 8*8kB (R) 22*16kB (R) 1*32kB (R) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 452kB
    [ 100.440000] 332 total pagecache pages
    [ 100.440000] 0 pages in swap cache
    [ 100.440000] Swap cache stats: add 0, delete 0, find 0/0
    [ 100.440000] Free swap = 0kB
    [ 100.440000] Total swap = 0kB
    [ 100.440000] 4096 pages RAM
    [ 100.440000] 0 pages HighMem/MovableOnly
    [ 100.770000] 819 pages reserved
    [ 100.770000] [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name
    [ 100.790000] [ 373] 0 373 222 19 3 0 0 ubusd
    [ 100.810000] [ 374] 0 374 192 14 3 0 0 askfirst
    [ 100.810000] [ 655] 0 655 262 40 4 0 0 logd
    [ 100.840000] [ 689] 0 689 386 58 4 0 0 netifd
    [ 100.850000] [ 701] 0 701 296 43 4 0 0 odhcpd
    [ 100.870000] [ 738] 0 738 287 19 4 0 0 dropbear
    [ 100.890000] [ 784] 0 784 382 38 4 0 0 uhttpd
    [ 100.890000] [ 823] 0 823 378 26 5 0 0 hotplug-call
    [ 100.920000] [ 824] 0 824 406 60 3 0 0 mac80211.sh
    [ 100.940000] [ 841] 0 841 379 27 5 0 0 hotplug-call
    [ 100.950000] [ 844] 0 844 370 19 5 0 0 ntpd
    [ 100.970000] [ 918] 0 918 457 58 4 0 0 fw3
    [ 100.980000] [ 924] 0 924 430 44 5 0 0 hostapd
    [ 101.000000] [ 925] 0 925 367 20 3 0 0 cat
    [ 101.020000] Out of memory: Kill process 824 (mac80211.sh) score 18 or sacrifice child
    [ 101.020000] Killed process 925 (cat) total-vm:1468kB, anon-rss:40kB, file-rss:40kB
    [ 105.390000] odhcpd invoked oom-killer: gfp_mask=0x201da, order=0, oom_score_adj=0
    [ 105.410000] CPU: 0 PID: 701 Comm: odhcpd Not tainted 3.14.18 #15
    [ 105.420000] Stack : 00000000 00000000 00000000 00000000 8031ad2e 00000034 808c1038 00000000
    80279824 802bc697 000002bd 8031399c 808c1038 00000000 802bc048 802bc164
    00000000 80223678 00000000 8018ed58 00000006 00000020 8027c9b4 805f1bb4
    00000000 00000000 00000000 00000000 00000000 00000000 00000000 805f1b40
    [ 105.490000] Call Trace:
    [ 105.490000] [<801caf80>] show_stack+0x48/0x70
    [ 105.510000] [<80222c9c>] dump_header.isra.17+0x4c/0x13c
    [ 105.510000] [<8016f938>] oom_kill_process+0xc8/0x3c8
    [ 105.530000] [<801708b4>] out_of_memory+0x2f0/0x328
    [ 105.530000] [<80026530>] __alloc_pages_nodemask+0x684/0x6e8
    [ 105.550000] [<800d9b20>] filemap_fault+0x214/0x3e4
    [ 105.550000] [<80030934>] __do_fault+0xd0/0x4fc
    [ 105.570000] [<800f65a8>] handle_mm_fault+0x220/0x98c
    [ 105.570000] [<80031108>] __do_page_fault+0x168/0x3c0
    [ 105.590000] [<80004420>] ret_from_exception+0x0/0x10
    [ 105.590000]
    [ 105.590000] Mem-Info:
    [ 105.600000] Normal per-cpu:
    [ 105.610000] CPU 0: hi: 0, btch: 1 usd: 0
    [ 105.610000] active_anon:478 inactive_anon:5 isolated_anon:0
    [ 105.610000] active_file:129 inactive_file:189 isolated_file:0
    [ 105.610000] unevictable:0 dirty:0 writeback:0 unstable:0
    [ 105.610000] free:113 slab_reclaimable:120 slab_unreclaimable:1131
    [ 105.610000] mapped:27 shmem:9 pagetables:57 bounce:0
    [ 105.610000] free_cma:0
    [ 105.680000] Normal free:452kB min:452kB low:564kB high:676kB active_anon:1912kB inactive_anon:20kB active_file:516kB inactive_file:756kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:16384kB managed:13108kB mlocked:0kB dirty:0kB writeback:0kB mapped:108kB shmem:36kB slab_reclaimable:480kB slab_unreclaimable:4524kB kernel_stack:288kB pagetables:228kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:2029 all_unreclaimable? yes
    [ 105.680000] lowmem_reserve[]: 0 0
    [ 105.680000] Normal: 1*4kB (R) 8*8kB (R) 22*16kB (R) 1*32kB (R) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 452kB
    [ 105.680000] 327 total pagecache pages
    [ 105.680000] 0 pages in swap cache
    [ 105.680000] Swap cache stats: add 0, delete 0, find 0/0
    [ 105.680000] Free swap = 0kB
    [ 105.680000] Total swap = 0kB
    [ 105.680000] 4096 pages RAM
    [ 105.680000] 0 pages HighMem/MovableOnly
    [ 105.680000] 819 pages reserved
    [ 105.680000] [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name
    [ 105.680000] [ 373] 0 373 222 19 3 0 0 ubusd
    [ 105.680000] [ 374] 0 374 192 14 3 0 0 askfirst
    [ 105.680000] [ 655] 0 655 262 44 4 0 0 logd
    [ 105.680000] [ 689] 0 689 386 58 4 0 0 netifd
    [ 105.680000] [ 701] 0 701 296 43 4 0 0 odhcpd
    [ 105.680000] [ 738] 0 738 287 19 4 0 0 dropbear
    [ 105.680000] [ 784] 0 784 382 38 4 0 0 uhttpd
    [ 105.680000] [ 823] 0 823 378 26 5 0 0 hotplug-call
    [ 105.680000] [ 824] 0 824 406 62 3 0 0 mac80211.sh
    [ 106.010000] [ 841] 0 841 379 27 5 0 0 hotplug-call
    [ 106.020000] [ 844] 0 844 370 18 5 0 0 ntpd
    [ 106.040000] [ 918] 0 918 457 56 4 0 0 fw3
    [ 106.060000] [ 924] 0 924 430 54 5 0 0 hostapd
    [ 106.060000] Out of memory: Kill process 824 (mac80211.sh) score 19 or sacrifice child
    [ 106.090000] Killed process 824 (mac80211.sh) total-vm:1624kB, anon-rss:236kB, file-rss:12kB
    [ 109.120000] procd invoked oom-killer: gfp_mask=0x201da, order=0, oom_score_adj=0
    [ 109.120000] CPU: 0 PID: 1 Comm: procd Not tainted 3.14.18 #15
    [ 109.140000] Stack : 00000000 00000000 00000000 00000000 8031ad2e 00000031 8082c228 00000000
    80279824 802bc697 00000001 8031399c 8082c228 00000000 802bc048 802bc164
    00000000 80223678 00000000 8018ed58 00000006 00000020 8027c9b4 8082bbb4
    00000000 00000000 00000000 00000000 00000000 00000000 00000000 8082bb40
    [ 109.210000] Call Trace:
    [ 109.210000] [<801caf80>] show_stack+0x48/0x70
    [ 109.230000] [<80222c9c>] dump_header.isra.17+0x4c/0x13c
    [ 109.230000] [<8016f938>] oom_kill_process+0xc8/0x3c8
    [ 109.250000] [<801708b4>] out_of_memory+0x2f0/0x328
    [ 109.250000] [<80026530>] __alloc_pages_nodemask+0x684/0x6e8
    [ 109.270000] [<800d9b20>] filemap_fault+0x214/0x3e4
    [ 109.270000] [<80030934>] __do_fault+0xd0/0x4fc
    [ 109.290000] [<800f65a8>] handle_mm_fault+0x220/0x98c
    [ 109.290000] [<80031108>] __do_page_fault+0x168/0x3c0
    [ 109.310000] [<80004420>] ret_from_exception+0x0/0x10
    [ 109.310000]
    [ 109.310000] Mem-Info:
    [ 109.320000] Normal per-cpu:
    [ 109.330000] CPU 0: hi: 0, btch: 1 usd: 0
    [ 109.340000] active_anon:419 inactive_anon:5 isolated_anon:0
    [ 109.340000] active_file:152 inactive_file:223 isolated_file:0
    [ 109.340000] unevictable:0 dirty:0 writeback:0 unstable:0
    [ 109.340000] free:113 slab_reclaimable:120 slab_unreclaimable:1131
    [ 109.340000] mapped:26 shmem:9 pagetables:54 bounce:0
    [ 109.340000] free_cma:0
    [ 109.400000] Normal free:452kB min:452kB low:564kB high:676kB active_anon:1676kB inactive_anon:20kB active_file:608kB inactive_file:892kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:16384kB managed:13108kB mlocked:0kB dirty:0kB writeback:0kB mapped:104kB shmem:36kB slab_reclaimable:480kB slab_unreclaimable:4524kB kernel_stack:280kB pagetables:216kB unstable:0kB bounce:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:2328 all_unreclaimable? yes
    [ 109.480000] lowmem_reserve[]: 0 0
    [ 109.490000] Normal: 1*4kB (R) 6*8kB (R) 23*16kB (R) 1*32kB (R) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 452kB
    [ 109.510000] 384 total pagecache pages
    [ 109.510000] 0 pages in swap cache
    [ 109.530000] Swap cache stats: add 0, delete 0, find 0/0
    [ 109.530000] Free swap = 0kB
    [ 109.530000] Total swap = 0kB
    [ 109.550000] 4096 pages RAM
    [ 109.550000] 0 pages HighMem/MovableOnly
    [ 109.550000] 819 pages reserved
    [ 109.570000] [ pid ] uid tgid total_vm rss nr_ptes swapents oom_score_adj name
    [ 109.570000] [ 373] 0 373 222 19 3 0 0 ubusd
    [ 109.600000] [ 374] 0 374 192 14 3 0 0 askfirst
    [ 109.610000] [ 655] 0 655 262 44 4 0 0 logd
    [ 109.610000] [ 689] 0 689 386 66 4 0 0 netifd
    [ 109.610000] [ 701] 0 701 296 47 4 0 0 odhcpd
    [ 109.610000] [ 738] 0 738 287 19 4 0 0 dropbear
    [ 109.610000] [ 784] 0 784 382 38 4 0 0 uhttpd
    [ 109.610000] [ 823] 0 823 378 26 5 0 0 hotplug-call
    [ 109.610000] [ 841] 0 841 379 27 5 0 0 hotplug-call
    [ 109.610000] [ 844] 0 844 370 18 5 0 0 ntpd
    [ 109.610000] [ 918] 0 918 457 58 4 0 0 fw3
    [ 109.610000] [ 924] 0 924 430 47 5 0 0 hostapd
    [ 109.610000] Out of memory: Kill process 689 (netifd) score 20 or sacrifice child
    [ 109.610000] Killed process 823 (hotplug-call) total-vm:1512kB, anon-rss:104kB, file-rss:0kB
Re: Mistakes after repairing of VoCore
Mon Feb 09, 2015 6:41 am
I update that post, sorry for such trouble.
Your issue might be bootstrap problem. Read the sch and check if every pull up/down resistor is in right position.
Or connect every GND to real GND, and check if every cap is connected.
deshipu
Tue Feb 10, 2015 4:01 pm
I usually get the OOM killer when the power is noisy or not high enough during the startup. Then VoCore detects only part of its memory, and it's either too little to start the kernel at all, or it just runs very slow and can't start any larger program.
1kvi1
Wed Mar 11, 2015 4:56 am
Hi, all!
Sorry for long time answer. I found that reasine for this trouble is bootstrap pin's state.
So, I start my vocore without uart cable and now its ok!
Thank you!
Users browsing this forum: Baidu [Spider] and 97 guests
