I was wiring the VoCore to power on a Raspberry Pi A+ with an external battery and mistook the 3v for a ground.. smoke, heat.. and now it's dead
I won't be able to do any more tests until I get another one.. maybe 5 weeks.
I fried my VoCore
- Endat
Re: I fried my VoCore
I just ordered a couple more. Hopefully they can ship out before Chinese new year
Edit: I just found out that it's not totally ruined.. but I have lost the use of both 3.5v-6.0v inputs. I can still power it with a 3.7v battery.
For a smart guy, I can be pretty dumb sometimes..
- Endat
So I've tracked the problem down. I can still use the VoCore, powering it with a 3.7v cell phone battery, but whenever I try to power it using the 3.5-6.0v pins, the following circuit jumps to about 200 degrees immediately. You can even see a brown burn mark. If I replace this, maybe I will have full use of the unit again.. what is this circuit and how do I get one? I think it says "AS11Dh" or "AS110h"
Is it a voltage regulator? I found these, but not sure if they would fit.
http://www.ti.com/product/lm2734
http://eastech.en.seekic.com/product/in ... X-3_6.html
- Greenwire-Elektronik
It is a MT3410L according to schematics, layout and BOM. It seams that it is a part which will not be sold on the regular places apart from aliexpress.
- Ruphobia
I took a quick look at digikey to see if there was a suitable replacement. There are some that are close but not quite there (by specifications). I hate it when people use parts that are unobtainium
If you list them i can check the datasheets and find a replacement!
- Endat
Would it be possible to upgrade to one that has this overvoltage / temp protection?
- charliex
i didn't look too hard, but a quick scan i see lp3208, a7115
Users browsing this forum: No registered users and 60 guests
