Where to find kmod-usb-hid package?
aarobc
Mon Feb 23, 2015 5:51 am
I've compiled openwrt with kmod-usb-hid support as indicated here: http://h-wrt.com/en/doc/kb
but I run into a few problems.
First, the repositories generated are all broken in opkg.conf. I replaced them with the one from nobilepepper as found here: viewtopic.php?f=2&t=262&start=10
that provided a few working packages but the one I need is still absent. Is this something I'm going to need to find and compile?
Thanks for the help, I'm really loving this platform.
Re: Where to find kmod-usb-hid package?
Mon Feb 23, 2015 12:45 pm
I compiled asnd installed that package without any problem. Maybe get the new openwrt trunk and compile full source again will fix such problem?
Mon Feb 23, 2015 1:58 pm
I don't remember why I didn't include kmod-usb-hid in the repositories I put together, but you are quite correct it is not there.
What do you mean by
? What does your opkg.conf look like?
You may want to look at opkg update doesn't work.
If you want to use a package you built you need to transfer it to the vocore and then reference it by the full pathname.
In debian I:
scp bin/ramips/packages/base/kmod-usb-hid_3.18.7-1_ramips_24kec.ipk root@192.168.x.xxx:/root
Then on the vocore I:
opkg install /root/kmod-usb-hid_3.18.7-1_ramips_24kec.ipk
aarobc
Wed Feb 25, 2015 2:02 am
The listed repos weren't resolving. I replaced them with the ones that you listed and it installed and worked great, much appreciated.
Users browsing this forum: No registered users and 75 guests
