WiFi rather slow and weak signal
Posted: Sat Nov 05, 2016 1:42 pm
by docbee
I had some tries yesterday to get WiFi running (as a client to my WLAN) and this was a much longer experiment than expected. At first I thought my configs were wrong as I could not get any connection. In the end it turned out that WiFi reception of vocore is rather limited. Singal levels are way below other WiFi clients also located in my room. I guess this has to do with the chip antenna and RF being largely blocked/reflected as being surrounded by metal components of the vocore dock. I did not try with pure vocore chips (without the dock).
Do you also have this experience or does vocore work on par with other wifi clients in your household?
My wireless settings are rather standard. May be there are some options missing to give it a kick forward?
config wifi-device radio0
option type mac80211
option channel 'auto'
option hwmode 11g
option path '10180000.wmac'
option htmode HT20
Re: WiFi rather slow and weak signal
Posted: Sun Nov 13, 2016 2:40 pm
Hi, it is the openwrt 80211n driver issue, but for normal usage, the speed is enough.
If you want to reach full speed 73Mbps, have to use the close sourced MediaTek wireless driver.
Posted: Sun Nov 13, 2016 2:57 pm
by docbee
Thanks for your reply. But speed is not my issue, I don't need much of it. What makes me trouble is that the connection does only come up stable when the vocore dock is oriented in a specific direction on my table. Otherwise even getting a client IP via DHCP and registering the DNS is failing on the vocore. Signal level is at about -66db, which is reasonable good imho.
ifconfig wlan0:
wlan0 Link encap:Ethernet HWaddr B8:D8:12:66:26:D7
inet addr:192.168.123.245 Bcast:192.168.123.255 Mask:255.255.255.0
inet6 addr: fe80::bad8:12ff:fe66:26d7/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:3379 errors:0 dropped:0 overruns:0 frame:0
TX packets:184 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:323317 (315.7 KiB) TX bytes:25640 (25.0 KiB)
route:
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.123.1 0.0.0.0 UG 0 0 0 wlan0
192.168.61.0 * 255.255.255.0 U 0 0 0 br-lan
192.168.123.0 * 255.255.255.0 U 0 0 0 wlan0
ping -w 10
www.google.com- Code: Select all
ping: bad address 'www.google.com'
ping -w 10 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
--- 8.8.8.8 ping statistics ---
10 packets transmitted, 0 packets received, 100% packet loss
iw dev wlan0 scan
BSS 80:2a:a8:17:9a:06(on wlan0) -- associated
TSF: 601279649594 usec (6d, 23:01:19)
freq: 2412
beacon interval: 100 TUs
capability: ESS Privacy ShortPreamble ShortSlotTime (0x0431)
signal: -66.00 dBm
last seen: 200 ms ago
Information elements from Probe Response frame:
SSID: wave
Supported rates: 1.0* 2.0* 5.5* 11.0* 6.0 9.0 12.0 18.0
DS Parameter set: channel 1
ERP: <no flags>
Extended supported rates: 24.0 36.0 48.0 54.0
HT capabilities:
Capabilities: 0x1ac
HT20
SM Power Save disabled
RX HT20 SGI
TX STBC
RX STBC 1-stream
Max AMSDU length: 3839 bytes
No DSSS/CCK HT40
Maximum RX AMPDU length 65535 bytes (exponent: 0x003)
Minimum RX AMPDU time spacing: 8 usec (0x06)
HT TX/RX MCS rate indexes supported: 0-23
HT operation:
* primary channel: 1
* secondary channel offset: no secondary
* STA channel width: 20 MHz
* RIFS: 0
* HT protection: non-HT mixed
* non-GF present: 1
* OBSS non-GF present: 1
* dual beacon: 0
* dual CTS protection: 0
* STBC beacon: 0
* L-SIG TXOP Prot: 0
* PCO active: 0
* PCO phase: 0
Extended capabilities: 6
WMM: * Parameter version 1
* BE: CW 15-1023, AIFSN 3
* BK: CW 15-1023, AIFSN 7
* VI: CW 7-15, AIFSN 2, TXOP 3008 usec
* VO: CW 3-7, AIFSN 2, TXOP 1504 usec
RSN: * Version: 1
* Group cipher: CCMP
* Pairwise ciphers: CCMP
* Authentication suites: PSK
* Capabilities: 1-PTKSA-RC 1-GTKSA-RC (0x0000)
Any ideas how to pimp WiFi reliability? As is I cannot build a product on this.
