Recipe to give vocore 2nd serial port
Posted: Sat Nov 05, 2016 10:55 pm
by docbee
The RT5350 chip of vocore provides two UART ports. One with full control line support (RTS/CTS/DTR/DSR/DTS) called uartf (uartfull) and another one just with RX/TX lines called uart (uartlite). vocore is configured to make use only of the uartlite port and to use it as a serial console mapped to "/dev/ttyS0".
As I needed another serial port, I worked on bringing the 2nd uart port to live as /dev/ttyS1. When you replace the files "VOCORE.dts" and "rt5350.dtsi" with versions shown below, you are done. These files add the uartfull port in a way that just lines GPIO 7-10 are used for the serial communication and keep GPIO 11 - 14 as GPIO lines.
VOCORE.dtsi
/dts-v1/;
/include/ "rt5350.dtsi"
   compatible = "VoCore", "ralink,rt5350-soc";
   model = "VoCore";
   palmbus@10000000 {
      sysc@0 {
         ralink,uartmux = "gpio uartf";
      gpio1: gpio@660 {
         status = "okay";
      i2c@900 {
         status = "okay";
      spi@b00 {
         status = "okay";
         m25p80@0 {
            #address-cells = <1>;
            #size-cells = <1>;
            compatible = "s25fl064k";
            reg = <0>;
            linux,modalias = "m25p80", "s25fl064k";
            spi-max-frequency = <10000000>;
            partition@0 {
               label = "uboot";
               reg = <0x0 0x30000>;
               read-only;
            partition@30000 {
               label = "uboot-env";
               reg = <0x30000 0x10000>;
               read-only;
            factory: partition@40000 {
               label = "factory";
               reg = <0x40000 0x10000>;
               read-only;
            partition@50000 {      // 16 MB FLASH MODEL
               label = "firmware";
               reg = <0x50000 0xfb0000>;
         spidev@1 {
            compatible = "linux,spidev";
            reg = <1>;
   pinctrl {
      state_default: pinctrl0 {
         gpio {
            ralink,group = "jtag", "led";   // "uartf" removed to have 2nd UART working
            ralink,function = "gpio";
   ethernet@10100000 {
      mtd-mac-address = <&factory 0x4>;
   esw@10110000 {
      ralink,portmap = <0x17>;
   wmac@10180000 {
      ralink,mtd-eeprom = <&factory 0>;
   ehci@101c0000 {
      status = "okay";
   ohci@101c1000 {
      status = "okay";
   gpio-export {
      compatible = "gpio-export";
      #size-cells = <0>;
      gpio0 {
         gpio-export,name = "gpio0";
         gpio-export,direction_may_change = <1>;
         gpios = <&gpio0 0 0>;
      /* SHARED UARTF */
      gpio11 {
         // UARTF_CTS_N
         gpio-export,name = "gpio9";
         gpios = <&gpio0 9 0>;
      gpio12 {
         // UARTF_DCD_N
         gpio-export,name = "gpio12";
         gpios = <&gpio0 12 0>;
      gpio13 {
         // UARTF_DSR_N
         gpio-export,name = "gpio13";
         gpios = <&gpio0 13 0>;
      gpio14 {
         // UARTF_RIN
         gpio-export,name = "gpio14";
         gpios = <&gpio0 14 0>;
      /* JTAG */
      gpio17 {
         /* JTAG_TDO */
         gpio-export,name = "gpio17";
         gpios = <&gpio0 17 0>;
      gpio18 {
         /* JTAG_TDI */
         gpio-export,name = "gpio18";
         gpios = <&gpio0 18 0>;
      gpio19 {
         /* JTAG_TMS */
         gpio-export,name = "gpio19";
         gpios = <&gpio0 19 0>;
      gpio20 {
         /* JTAG_TCLK */
         gpio-export,name = "gpio20";
         gpios = <&gpio0 20 0>;
      gpio21 {
         /* JTAG_TRST_N */
         gpio-export,name = "gpio21";
         gpios = <&gpio0 21 0>;
      /* ETH LEDs */
      gpio22 {
         /* ETH0_LED */
         gpio-export,name = "gpio22";
         gpios = <&gpio1 0 0>;
      gpio23 {
         // ETH1_LED
         gpio-export,name = "gpio23";
         gpios = <&gpio1 1 0>;
      gpio24 {
         // ETH2_LED
         gpio-export,name = "gpio24";
         gpios = <&gpio1 2 0>;
      gpio25 {
         // ETH3_LED
         gpio-export,name = "gpio25";
         gpios = <&gpio1 3 0>;
      gpio26 {
         /* ETH4_LED */
         gpio-export,name = "gpio26";
         gpios = <&gpio1 4 0>;
   gpio-leds {
      compatible = "gpio-leds";
      status {
         /* UARTF_RXD */
         label = "vocore:green:status";
         gpios = <&gpio0 10 0>;
      eth {
         /* UARTF_DTR_N */
         label = "vocore:orange:eth";
         gpios = <&gpio0 11 0>;
      signal {
         // GPIO 23
         label = "vocore:red:signal";
         gpios = <&gpio0 1 0>;
   gpio-keys-polled {
      compatible = "gpio-keys-polled";
      #size-cells = <0>;
      poll-interval = <20>;
      reset {
         label = "reset";
         gpios = <&gpio1 3 0>;   // reset button, gpio 25
         linux,code = <0x198>;
      BTN_0 {
         label = "mode";
         gpios = <&gpio1 3 0>;   // mode button, gpio 25
         linux,code = <0x100>;   // BTN_0
      BTN_1 {
         label = "showip";
         gpios = <&gpio1 2 0>;   // showip button, gpio 24
rt5350.dts
   #size-cells = <1>;
   compatible = "ralink,rt5350-soc";
   cpus {
      cpu@0 {
         compatible = "mips,mips24KEc";
   chosen {
      bootargs = "console=ttyS0,57600";
   cpuintc: cpuintc@0 {
      #address-cells = <0>;
      #interrupt-cells = <1>;
      interrupt-controller;
      compatible = "mti,cpu-interrupt-controller";
   palmbus@10000000 {
      compatible = "palmbus";
      reg = <0x10000000 0x200000>;
      ranges = <0x0 0x10000000 0x1FFFFF>;
      #size-cells = <1>;
      sysc@0 {
         compatible = "ralink,rt5350-sysc", "ralink,rt3050-sysc";
         reg = <0x0 0x100>;
      timer@100 {
         compatible = "ralink,rt5350-timer", "ralink,rt2880-timer";
         reg = <0x100 0x20>;
         interrupt-parent = <&intc>;
         interrupts = <1>;
      watchdog@120 {
         compatible = "ralink,rt5350-wdt", "ralink,rt2880-wdt";
         reg = <0x120 0x10>;
         resets = <&rstctrl 8>;
         reset-names = "wdt";
         interrupts = <1>;
      intc: intc@200 {
         compatible = "ralink,rt5350-intc", "ralink,rt2880-intc";
         reg = <0x200 0x100>;
         resets = <&rstctrl 19>;
         reset-names = "intc";
         interrupt-parent = <&cpuintc>;
         interrupts = <2>;
      memc@300 {
         compatible = "ralink,rt5350-memc", "ralink,rt3050-memc";
         reg = <0x300 0x100>;
         resets = <&rstctrl 20>;
         reset-names = "mc";
         interrupts = <3>;
      uartlite@c00 {
         compatible = "ralink,rt5350-uart", "ralink,rt2880-uart", "ns16550a";
         reg = <0xc00 0x100>;
         reset-names = "uartl";
         interrupts = <12>;
         pinctrl-names = "default";
         pinctrl-0 = <&uartlite_pins>;
         reg-shift = <2>;
      uart@500 {
         reg = <0x500 0x100>;
         resets = <&rstctrl 12>;
         reset-names = "uart";
         interrupts = <5>;
         reg-shift = <2>;
         pinctrl-0 = <&uartf_pins>;
//         status = "disabled";
      gpio0: gpio@600 {
         compatible = "ralink,rt5350-gpio", "ralink,rt2880-gpio";
         reg = <0x600 0x34>;
         resets = <&rstctrl 13>;
         reset-names = "pio";
         interrupts = <6>;
         gpio-controller;
         #gpio-cells = <2>;
         ralink,gpio-base = <0>;
         ralink,num-gpios = <22>;
         ralink,register-map = [ 00 04 08 0c
                  20 24 28 2c
                  30 34 ];
      gpio1: gpio@660 {
         reg = <0x660 0x24>;
         interrupts = <6>;
         gpio-controller;
         #gpio-cells = <2>;
         ralink,gpio-base = <22>;
         ralink,num-gpios = <6>;
                  10 14 18 1c
                  20 24 ];
      i2c@900 {
         compatible = "link,rt5350-i2c", "ralink,rt2880-i2c";
         reg = <0x900 0x100>;
         resets = <&rstctrl 16>;
         reset-names = "i2c";
         #size-cells = <0>;
         pinctrl-0 = <&i2c_pins>;
      spi@b00 {
         compatible = "ralink,rt5350-spi";
         reg = <0xb00 0x100>;
         resets = <&rstctrl 18>;
         reset-names = "spi";
         #size-cells = <1>;
         pinctrl-0 = <&spi_pins &spi_cs1>;
      systick@d00 {
         compatible = "ralink,rt5350-systick", "ralink,cevt-systick";
         reg = <0xd00 0x10>;
         interrupts = <7>;
   pinctrl {
      compatible = "ralink,rt2880-pinmux";
      pinctrl-0 = <&state_default>;
      spi_pins: spi {
         spi {
            ralink,group = "spi";
            ralink,function = "spi";
      i2c_pins: i2c {
         i2c {
            ralink,group = "i2c";
            ralink,function = "i2c";
      phy_led_pins: phy_led {
         phy_led {
            ralink,group = "led";
            ralink,function = "led";
      uartlite_pins: uartlite {
         uart {
            ralink,group = "uartlite";
            ralink,function = "uartlite";
      uartf_pins: uartf {
         uartf {
            ralink,group = "uartf";
            ralink,function = "uartf";
      spi_cs1: spi1 {
         spi1 {
            ralink,group = "spi_cs1";
            ralink,function = "spi_cs1";
   rstctrl: rstctrl {
      compatible = "ralink,rt5350-reset", "ralink,rt2880-reset";
      #reset-cells = <1>;
   usbphy {
      compatible = "ralink,rt3xxx-usbphy";
      resets = <&rstctrl 22 &rstctrl 25>;
      reset-names = "host", "device";
   ethernet@10100000 {
      compatible = "ralink,rt5350-eth";
      reg = <0x10100000 10000>;
      interrupts = <5>;
   esw@10110000 {
      compatible = "ralink,rt3050-esw";
      reg = <0x10110000 8000>;
      interrupts = <17>;
   wmac@10180000 {
      compatible = "ralink,rt5350-wmac", "ralink,rt2880-wmac";
      reg = <0x10180000 40000>;
      interrupts = <6>;
      ralink,eeprom = "soc_wmac.eeprom";
   ehci@101c0000 {
      compatible = "ralink,rt3xxx-ehci", "ehci-platform";
      reg = <0x101c0000 0x1000>;
      interrupts = <18>;
   ohci@101c1000 {
      compatible = "ralink,rt3xxx-ohci", "ohci-platform";
      reg = <0x101c1000 0x1000>;
      interrupts = <18>;
Re: Recipe to give vocore 2nd serial port
Posted: Sat Nov 05, 2016 10:59 pm
by docbee
To spare you looking into the manual, the pins to use for /dev/ttyS1 are:
TX -> GPIO 08
RX -> GPIO 10
and
CTS -> GPIO 09
RTS -> GPIO 07
in case you need hardware handshake
Posted: Fri Mar 17, 2017 10:43 pm
by chrisck87
Hi!
I'm a new Vocore and linux user, where do I need to replace those files? are there in my PC or in some direction inside the vocore?. In my PC I have two paths with the dts and dtsi files you mentioned, the first in in ...openwrt/target/linux/ramips/dts and the other is in ...openwrt/buil_dir/target_mipsel.../openwrt-sdk.../target/linux/ramips/dts
Thanks for helping
