Can you use a micro sd card in it?
Posted: Sun Mar 22, 2015 11:48 am
by Raymond Day
This is a super neat super small router. The VoCore + doc has a micro SD card slot on it too. I guess can put up to 32GB card in it but will it see it then? Can it be mounted?
If so how? What would be the commands or can you do it though the http cgi-bin/luci settings?
Re: Can you use a micro sd card in it?
Posted: Mon Mar 23, 2015 1:43 am
It should be able to support 32GB SD card, I tested 8GB, but speed is slow, about 100KB/s. :)
That will need some skill to support that, you need file system driver and update SPI driver with my patch on my blog.
