I had some connectors soldered on the board, including for UARTL_RXD2 and UARTL_TXD2.
I wanted to solder new headers, so I removed the old connectors I had soldered weeks before.
In this process I broke something on RXD2 pin, I think I broke the connection with the corresponding pin from RT5350 chipset (the copper plate from inside and near the hole got out).
I would like to solder directly to the resistor R318, so UARTL_RXD2 will work again.
But I am not sure where R318 is located exactly on the board, I don't find it in the schematics.
Can you help me with this?
Thank you
Resolder RXD2 pin
- ion.dulgheru
Re: Resolder RXD2 pin
It should be the fourth resistor on left-bottom of VoCore.
You can download a PADS viewer to get the information.
- charliex
- ion.dulgheru
Users browsing this forum: No registered users and 129 guests
