Hey guys, first off I do apologize for being new to working with hardware like this.
I am trying to build a prototype piece of hardware that does the following:
- hosts a wifi network as a switch (creating local intranet), allowing IP webcams to connect wirelessly
- supply video feeds from the IP webcams via OTG cable to mobile device
Thanks for all your help and any advice if I should inquire elsewhere maybe.
Travis
Can VoCore Host WiFi Intranet Allowing Clients To Connect?
- Travisbklein
- Ruphobia
Re: Can VoCore Host WiFi Intranet Allowing Clients To Connec
Hello Travis,
This should work without doing anything other than connecting your web cameras to the vocore.
When you say mobile device, do you mean Android and or IOS?
I don't know how you would do this with IOS, however, I do know how to do this with and Android device:
1) cross compile ADB or find a MIPS binary of ADB
2) install ADB on the vocore
3) in the boot up script of the vocore, setup port forwarding using ADB
The command would look something like: adb forward <local> <remote>
This essentially tethers the android device onto the vocore network bridging the android and the cameras.
It's been awhile since I've done this, I believe there is one additional step required for routes and the like, however, this should be enough information to get you started in the right direction.
