OK I have tried doing this over and over again, I even had to upload firmware through UART to start from scratch and still not having any luck.
I was able to do this on another Vocore but for some reason I cannot on this one.
Can someone look at my screen shots and tell me if I am doing something wrong?
I even tried changing the ip from 192.168.61.1 to 192.168.1.1 in lan config and had no luck.
My wireless network shows up in Luci but if I try to enable it it won't.
Also, I am not able to see Vocore through my wifi after doing this
Any help is greatly appreciated!!!
Help with AP+STA
- rcpaul
Help with AP+STA
Re: Help with AP+STA
Do you setup the firewall?
You must allow it access firewall.
Please update /etc/config/firewall, add one line
config wifi-iface
option name wan
list network 'wan'
+ list network 'wwan'
list network 'wan6'
http://vocore.io/wiki/index/id:17
after that, it should work
config wifi-iface
option name wan
list network 'wan'
list network 'wan6'
- rcpaul
Yes thats the last screen shot shown. Not sure what i am doing wrong
Looks everything correct.
1. Check if AP mode(not AP+STA) works.
2. Check if STA mode works.
If both works, it must be config error.
Maybe special chars in your ssid?
- rcpaul
Vonger,
Vocore does not show up in my wifi after doing this, shouldn't it show up???
your config is not same as mine, use vonger.cn/upload/vocore16.bin to recover the firmware and follow the step on wiki again.
- rcpaul
OK tried it again, flashed the firmware and redid steps for AP+STA on wiki and still no luck.
Every time I complete AP+STA steps in wiki, when I reboot I cannot connect to Vocore through wifi.
Users browsing this forum: No registered users and 50 guests
