CS1 & SPI bus
Posted: Wed May 27, 2015 7:55 am
by obutler
I'm stuck on having the CS1 (SPI bus ) working.
I'm using a recent build of openwrt + vocore plateform.
On linux side, everything seems ok : spidev is here.
On hardware side : I've got datas and clock on the bus while I'm sending data on it.
But CS1 remains always at the high level.
Do I missing something ?
thanks for your help.
Olivier
Re: CS1 & SPI bus
Posted: Sat May 30, 2015 12:41 am
There is a system register default make CS1 as GPIO, change this to 2b00
GPIOMODE: GPIO Purpose Select (offset: 0x0060)
Bits 22:21 RW SPI_CS1_MODE default 0x2
2’b00: SPI_CS1
2’b01: Watchdog reset output (active low for 3 system clocks)
2’b10: GPIO mode
