Vocore2 PoE two ethernet ports
lppuser50
Tue Apr 21, 2020 8:44 pm
I can see that the vocore2+PoE dock has two ethernet ports.
Can both these ports be used for PoE, one to power up the vocore and the other to connect to a PoE device such as a PoE camera ?
Re: Vocore2 PoE two ethernet ports
Wed Apr 22, 2020 1:18 pm
It has only one PoE for power.
But VoCore2 has five ethernet ports if you do not need SDcard, all of them can use connect to other device, but none of them are PoE anymore.
Recently POE dock has a big upgrade, we removed transformer for the second ethernet port, add sdcard slot and USB port.
If you have a low power USB camera(less than 3watt), you can directly connect it to USB port, PoE is class2 max output 6w
murraythegoz
Fri Aug 12, 2022 11:00 am
Could you please add updated photos?
The current ones in https://vocore.io/poe.html don't show the sdcard and USB.
thank you
m.
Sat Aug 13, 2022 3:06 am
Yes :) recently PoE version is updating, we will combine Ultimate and POE version.
So it will be updated later.
