Not booting to get a IP.
Raymond Day
Mon Jun 22, 2015 4:36 am
My bother wanted one so I order 2 of them and he just bought his back because it don't get a IP address. I put a RS232 on it. He said he wants it for that.
I seen he had the plug to the 3.3 volt on the RS232. He must of plug it back in wrong. So I put it right.
Can look at the boot up and it stops like this:
procd: - early -
procd: - watchdog -
procd: - ubus -
procd: - init -
procd: - init complete -
/sbin/askfirst: Please press Enter to activate this console.
[   44.460000] random: nonblocking pool is initialized
Is there a way though the RS232 to set it back to like factory default?
I can hit X to go to:
Version: May 30 2014 20:52:36
Press 'x' to console...
VoCore>
Any thing I can do from that to make this work again?
-Raymond Day
Raymond Day
Re: Not booting to get a IP.
Mon Jun 22, 2015 1:27 pm
So is there a way to restore the VoCore just how they send it out. How do they set it up when they send it out?
-Raymond Day
Raymond Day
Tue Jun 23, 2015 12:05 pm
Found I link that I guess could restore this thought the RS232. But I just don't get how.
Using putty I can press the x to console real fast. Then I type the loadb and it is waiting for a (kermit) upload to it. I remember that old file upload/download on my old Commodore 64 the old phone modem days. But how would I do it in Putty if that is the way.
The link says "uartlite" is there a link to download that if that is a term that can upload using kermit?
-Raymond Day
Raymond Day
Tue Jun 23, 2015 12:32 pm
Is there a way to put a SD card in the VoCore with a restore image on it and give it some command on the RS232 to restore it from the SD card?
-Raymond Day
Raymond Day
Tue Jun 23, 2015 1:39 pm
Hook it up to my Ubuntu server and used minicom. I can pick to upload like this:
jffs2 is ready
jffs2 is ready        .
[   12.610000] jffs2: notice: (318) jffs2_build_xattr_subsystem: complete build
switching to overlay
procd: - early -             +-[Upload]--+
procd: - watchdog -          | zmodem    |
procd: - ubus -              | ymodem    |
procd: - init -              | xmodem    |
Please press Enter to activat| kermit    |e.
procd: - init complete -     | ascii     |
VoCore> loadb
## Ready for binary (kermit) download to 0x80100000 at 57600 bps...
I pick the kermit and I all ready downloaded the 16MB .bin file with this command:
wget http://vonger.cn/upload/vocore16.bin
Then I pick it with space bar. vocore16.bin and press enter for "Okay" but it does nothing just goes back waiting for a upload looks like this:
VoCore> loadb
Just stays there. I guess the kermit upload don't work right in minicom for Linux.
Any one know what is wrong?
-Raymond Day
Raymond Day
Tue Jun 23, 2015 7:24 pm
Here are 3 photos of it not working so I guess they will help to show how can fix it.
https://goo.gl/photos/SY9QZuK4AgGL9QLp7
https://goo.gl/photos/zNgPepKroRZ1akEh8
https://goo.gl/photos/Pv4TvHAijxqukKQ88
I hope some one can tell me why it don't work. How to get it to work.
It would be good if some one said a Step-by-Step way.
-Raymond Day
Raymond Day
Tue Jun 23, 2015 11:38 pm
Wow what junk that it says use kermit. I just picked bin to test and it started to upload it!
No one could tell me that here. But I guess that's not the right way. Guess the bin file had the right code a way though to say start to download in Kermit way and that's were I started to see the count. But it was not right. I guess some error in the Kermit in minicom.
https://goo.gl/photos/TMHBd4VtzX7n1FVC8
That is a photo of the minicom using bin to send it. After it it shows text like this:
mdio   - Ralink PHY register R/W command !!
mm      - memory modify (auto-incrementing)
mw      - memory write (fill)
nm      - memory modify (constant address)
printenv- print environment variables
reset   - Perform RESET of the CPU
rf      - read/write rf register
saveenv - save environment variables to persistent storage
setenv  - set environment variables
Got to see what else to do and maybe this will boot now.
Raymond Day
Wed Jun 24, 2015 12:14 am
It just locked up then and I unplugged the power and it booted up the same way so it don't work. So I got in the Press X again on boot up.
Looks like can ftp it but it will be hard to set LAN to 10.10.10.3 ftp server and the VoCare on that.
I think I can do it with time. But no time now. I will see if I can do it with what I have.
-Raymond Day
Tue Jun 30, 2015 5:03 pm
there is two ways in uboot mode:
1. get a working kermit, then use kermit to upload it.
2. connect it to ethernet, use tftp to upload it.
there is one way in linux mode:
once it start up, it will show log about "failsafe mode", press "F + Enter" then goto failsafe mode and then call firstboot to recover all to normal.
brad
Sat Jul 04, 2015 9:36 am
Dude, minicom doesn't work! Vonger has described it here http://vocore.io/wiki/index/id:14 and http://vonger.cn/?p=780
MacOS program he uses is the linux "ckermit". So I give instructions here for ubuntu.
If using ubuntu.
sudo apt-get install ckermit
sudo kermit
at the prompt:
C-Kermit>
type:
set line /dev/ttyUSB0
define sz !sz \%0 > /dev/ttyUSB0 < /dev/ttyUSB0
set speed 57600
set carrier-watch off
set prefixing all
set parity none
set stop-bits 1
set modem none
set file type bin
set file name lit
set flow-control none
set prompt “vocore Kermit> ”
connect
turn on vocore and press x to get into boot loader
call 'loadb' to load data through kermit
press CTRL+ '\' then press 'c' to enter kermit command line to send file.
send <yourfile full directory>
call 'erase linux' to clear current linux section.
call 'cp.linux 3B0004' to flash the firmware from memory to flash.(3B0004 is an example, it should be your firmware size)
Note: if cp.linux size error, please call tftpboot then CTRL + C cancel, then cp.linux again, it should be ok.
Users browsing this forum: No registered users and 186 guests
