Kernel Version
dadiy
Kernel Version
Sat Nov 15, 2014 6:06 pm
I got my vocore delivered in the UK on Friday and it works great. Although when I tried to use opkg to install some packages Ive found that its running an older kernel.
Is there any easy way to update this to use the openwrt kernel 3.14.18-1 as this appears to be a dependancy for most packages, I wanted to install the bluetooth bluez package but that also requires this version.
Pyrofer
Re: Kernel Version
Sun Nov 16, 2014 10:46 am
I downloaded the openwrt build environment and selected the VoCore as target. You can build it all yourself easily then.
This is also the easiest way to cross-compile your own apps.
dadiy
Re: Kernel Version
Mon Nov 17, 2014 10:33 am
It would be really nice if someone could post a pre compiled latest software for vocore and instructions how to apply it?
dadiy
Re: Kernel Version
Mon Nov 17, 2014 11:34 am
I grabbed the latest version from the OpenWRT site but it turns out to be 3.10.49 which is a real shame.
dadiy
Re: Kernel Version
Wed Nov 19, 2014 10:10 am
Just following up on my own post.
For those too lazy to build their own openwrt package the latest bleeding edge version can be downloaded from the openwrt site here -
http://downloads.openwrt.org/snapshots/trunk/ramips/
Just look for the file named openwrt-ramips-rt305x-vocore-squashfs-sysupgrade.bin
I used Luci to upgrade, but note that the latest versions do not install Luci by default and that this needs to be added with opkg.
I also read that packages for these builds are rebuilt daily so if you load the bleeding edge and then try to add a package some time later they might be out of sync and the base OS would need to be reinstalled. At least until this branch moves to stable.
darksoul
Re: Kernel Version
Fri Nov 21, 2014 5:53 am
dadiy wrote:Just following up on my own post.
The Firmware that you suggested is not stable, vocore can freeze in the middle of something, or just reboot.
Did tests for 2 hours, 3 times did manual reset by removing power, 2 times self reboot.
undead
Re: Kernel Version
Fri Nov 21, 2014 10:19 am
I found vocore stable image exists in http://downloads.openwrt.org/barrier_br ... ps/rt305x/
Is anybody know, is image trully stable or have some bugs?
Users browsing this forum: Google Adsense [Bot] and 11 guests
