Hey guys!
Did any one had a chance to setup VPN Client on Vocore?
Having problems =(
VPN L2TP
- darksoul
- darksoul
Re: VPN L2TP
Vonger wrote:Do you solved the problem? Is VPN working now?
I flashed firmware from "https://downloads.openwrt.org/snapshots/trunk/ramips/" it does work, yes, but after a while the l2tp services stops because the board is out of memory.
Also, is it possible to get the .config from you? i would like to do some modifications.
Thank you
Re: VPN L2TP
I just use the official one.
Just remove all unnecessary compose, such as LuCI...That will save a lot of place.
- darksoul
Re: VPN L2TP
Vonger wrote:I just use the official one.
I'll modify the config for supporting some basic services that are used. If you are interested i can upload it somewhere.
Users browsing this forum: No registered users and 42 guests
