USB-cable connector failure
cengelberts
Thu Sep 08, 2016 6:59 pm
the VoCam264 FHD cable connection between the two pcbs is broken. Its broken at the bottom side of the camera pcb. There must be a small black part to secure the connection between the cable and the cable connector. Somehow this part isn't there anymore.
What can I do to repair the usb-cable connection?
wutong
Re: USB-cable connector failure
Sun Sep 18, 2016 11:49 am
I just tried some ways, and here is safest way:
1. heat connector off
2. pull metal off
3. put cover on
4. put metal on
of course you can bend cover plastic, then pull it in. it might break cover plastic.
cengelberts
Mon Oct 10, 2016 9:22 am
sorry for answering late.
I will try your approach, Thanks a lot.
Greetings,
Christoph
Sun Nov 13, 2016 2:42 pm
:) Emm, I should mention the connector only have 20 times life cycle and intend not to move once you get it.
I will update the content.
Return to VoCam264 & Screen
Users browsing this forum: No registered users and 69 guests
