VoCam264 Voltage Input
Posted: Fri Jan 20, 2017 12:22 am
by HelloWorldTeraByte
Is it possible to use a single cell Lithium ion(3.7v) battery to power the VoCam264 ?. In the reference sheet it says the VoCam needs 5V in. Or am I better to use a voltage booster?
Re: VoCam264 Voltage Input
Posted: Fri Jan 20, 2017 2:46 pm
It is using a standard USB 2.0 interface, so 5V battery is able to power up it, but you still need to connect its data wire.
Posted: Sat Jan 21, 2017 1:06 am
I have decided to remove the Lipoly battery from my project and use a off the shelf power bank.Yes thank you very much Vonger.
