How can I control/modify the H264 stream parameters?
For example, how can i modify the target bitrate, H264 compression parameters, define CBR/VBR rate control?
Controlling the H264 stream
- zvi
Re: Controlling the H264 stream
Please check UVC2.0, it is a standard UVC driver.
- zvi
It seems that the only thing i can control (using v4l2-ctl) is the sensor parameters (e.g. brightness, saturation,..)
Is there a way to control the camera's processing unit?
Ah, ye, here is an internal API
Just uploaded to http://vocore.io/camera.html, but most of the doc is in Chinese.
- zvi
Can you please write a simple driver that uses the internal-protocol to set/get the camera parameters?
Or give an example how to set the bitrate parameter of the H264 stream using the SnDspRw tool ?
Emm, that is expert usage. I read the chip manual there is a USB interface for that. You can use the GPIO example(based on libusb) and change the code a little to do that,
- zvi
I've seen the code. Still, it is not clear how to construct the command. The libusb tool has no example with a correct camera codes. The message structure (get/set parameter message format is not clear). Even if I compile the libusb tool, what is the syntax to use the GPIO codes in the attached documents?
Users browsing this forum: No registered users and 7 guests
