Damaged H.264 stream
Posted: Thu Feb 14, 2019 2:37 pm
by jab
After some time of using VoCam camera, a green segments started to appear in the H.264 video stream. See attached image. In higher resolutions, this error is more visible. This happens only in H.264 stream, MJPG stream is not affected at all.
Re: Damaged H.264 stream
Posted: Fri Feb 15, 2019 11:02 am
if power off it wait one minute then connect, is it same result?
Posted: Fri Feb 15, 2019 12:08 pm
by jab
Yes, this "Matrix" noise appears every time since the problem started occur.
Posted: Sun Feb 17, 2019 1:02 am
I see, I will contact the chip FAE, maybe it is firmware issue.
