Default Config VoCore2 Ultimate
betabrain
Thu Jan 12, 2017 9:26 pm
Where can I find the default / factory configuration for the VoCore2 Ultimate? I managed to mess up its wifi config within minutes of first use (config change via graphical interface). And unfortunately the instructions on the STA+AP page don't help:
root@OpenWrt:/# uci set wireless.sta.ssid=[HOMEWIFI]
uci: Invalid argument
root@OpenWrt:/# uci set wireless.sta.ssid='HOMEWIFI'
root@OpenWrt:/# uci set wireless.sta.ssid=HOMEWIFI
Re: Default Config VoCore2 Ultimate
Fri Jan 13, 2017 2:06 pm
[HOMEWIFI] this means replace with your home router wireless hotspot name.
please paste three config here: /etc/config/wireless, /etc/config/firmware, /etc/config/network
betabrain
Mon Jan 16, 2017 11:11 am
config wifi-device 'radio0'
        option type 'ralink'
        option variant 'mt7628'
        option country 'CH'
config wifi-iface
        option device 'radio0'
        option network 'wifi'
        option mode 'ap'
        option ssid 'VoCore'
        option encryption 'psk2'
        option key 'superman12345'
config defaults
        option syn_flood '1'
        option input 'ACCEPT'
        option output 'ACCEPT'
        option forward 'REJECT'
config zone
        option name 'lan'
        option forward 'ACCEPT'
        option network 'lan'
config zone
        option name 'wan'
        option input 'REJECT'
        option masq '1'
        option mtu_fix '1'
        option network 'wan wan6 wwan'
config forwarding
        option src 'lan'
        option dest 'wan'
config rule
        option name 'Allow-DHCP-Renew'
        option src 'wan'
        option proto 'udp'
        option dest_port '68'
        option target 'ACCEPT'
        option family 'ipv4'
config rule
        option name 'Allow-Ping'
        option src 'wan'
        option proto 'icmp'
        option icmp_type 'echo-request'
config rule
        option name 'Allow-IGMP'
        option src 'wan'
        option proto 'igmp'
config rule
        option name 'Allow-DHCPv6'
        option src 'wan'
        option proto 'udp'
        option src_ip 'fe80::/10'
        option src_port '547'
        option dest_ip 'fe80::/10'
        option dest_port '546'
        option family 'ipv6'
config rule
        option name 'Allow-MLD'
        option src 'wan'
        option proto 'icmp'
        list icmp_type '130/0'
        list icmp_type '131/0'
        list icmp_type '132/0'
        list icmp_type '143/0'
config rule
        option name 'Allow-ICMPv6-Input'
        option src 'wan'
        option proto 'icmp'
        list icmp_type 'echo-request'
        list icmp_type 'echo-reply'
        list icmp_type 'destination-unreachable'
        list icmp_type 'packet-too-big'
        list icmp_type 'time-exceeded'
        list icmp_type 'bad-header'
        list icmp_type 'unknown-header-type'
        list icmp_type 'router-solicitation'
        list icmp_type 'neighbour-solicitation'
        list icmp_type 'router-advertisement'
        list icmp_type 'neighbour-advertisement'
        option limit '1000/sec'
config rule
        option name 'Allow-ICMPv6-Forward'
        option src 'wan'
        option dest '*'
        option proto 'icmp'
config include
        option path '/etc/firewall.user'
config rule
        option src 'wan'
        option dest 'lan'
        option proto 'esp'
config rule
        option src 'wan'
        option dest 'lan'
        option dest_port '500'
        option proto 'udp'
/etc/config/network
config interface 'loopback'
        option ifname 'lo'
        option proto 'static'
        option ipaddr '127.0.0.1'
        option netmask '255.0.0.0'
config globals 'globals'
        option ula_prefix 'fd47:f447:6340::/48'
config interface 'lan'
        option ifname 'eth0.1'
        option force_link '1'
        option macaddr '00:0c:43:e1:76:28'
        option type 'bridge'
        option ipaddr '192.168.1.1'
        option ip6assign '60'
config interface 'wan'
        option ifname 'eth0.2'
        option macaddr '00:0c:43:e1:76:29'
        option proto 'dhcp'
config interface 'wan6'
        option proto 'dhcpv6'
config switch
        option name 'switch0'
        option reset '1'
        option enable_vlan '1'
config switch_vlan
        option device 'switch0'
        option vlan '1'
        option ports '1 2 3 4 6t'
config switch_vlan
        option vlan '2'
        option ports '0 6t'
config interface 'wwan'
        option proto 'dhcp'
config interface 'wifi'
        option ipaddr '192.168.2.1'
Tue Jan 17, 2017 12:41 am
Looks like it is normal, try firstboot -y and reboot your vocore, make the config back to default. check if it works.
betabrain
Tue Jan 17, 2017 12:16 pm
Thanks. The default config works. :D What is the recommended next step? Is there a firmware update I should do?
freaky2xd
Thu Jan 26, 2017 5:10 pm
hey I am a noob considering programming and stuff!
how exactly can I restore the vocore2+dock?
I messed up the settings and now there is no ap but the lights are both on...
I only know how to access the vocore via putty in order to get to the openwrt interface and then my knowledge is gone
Fri Jan 27, 2017 2:24 pm
freaky2xd wrote:hey I am a noob considering programming and stuff!
First, connect your vocore to your computer, then install usb2ttl driver on vocore.io/v2, finally login to console by TTL and run firstboot -y
Users browsing this forum: No registered users and 24 guests
