USB Device
- john.lusher
USB Device
What driver for Windows 10 will work with the VoCore to support USB 2.0?
Re: USB Device
Do you mean the VoCore2 Ultimate driver?
You can download at vocore.io/v2, and "install cdc driver" http://vonger.cn/misc/vocore2/tools/usb2ttl.zip
- john.lusher
Re: USB Device
What I was interested in was using the port for higher speeds than a virtual COM port, i.e. truly being USB 2 and moving data back and forth over the endpoints.
Re: USB Device
Try to use USB to ethernet, that can reach 100Mbps.
We also have a version with USB to ethernet, please contact support@vocore.io for that sample.
It will create a network adaptor on your computer and you can communicate with vocore2 by ethernet through usb port as a usb device.
- CuriousCat
Re: USB Device
Vonger wrote:Try to use USB to ethernet, that can reach 100Mbps.
This sounds neat, maybe you could do a blog post on how to enable it? I am compiling based on your github already so I think it would be an easy change?
Re: USB Device
CuriousCat wrote:Vonger wrote:Try to use USB to ethernet, that can reach 100Mbps.
This is another version of vocore2, replace USB2TTL to USB2Ethernet.
If you want this version, just email support@vocore.io. It is not for open sell yet.
- fmm
Re: USB Device
Hello gents,
I am trying to do a similar thing and I searched ALL the topics to find a similar issue, virtual Ethernet over USB (e.g. where Android device can perform tethering to the board), but it seems that some modules and commands are not available there (e.g. g_ether is not fount).
Any idea? thanks in advance ...
Re: USB Device
fmm wrote:Hello gents,
reply in viewtopic.php?f=16&t=3957
Users browsing this forum: Google [Bot] and 63 guests
