Dear Vonger,
Could you please "open source" .dts files for both VoCore devices with Dock, VoCore 2 Ultimate and VoCore Dock (old version)? These files have definition of the Dock pinout (already prewritten).
I recently can't find any of them to enclose to the OpenWRT source files for compilation needs.
This would definitely ease a compilation for a lot of people.
Right now OpenWRT community can compile it's firmware only for VoCore 2 and VoCore Light, which is cool! Since VoCore 2 Ultimate is from different price range, it would be good to be able to compile system for them as well.
Sincerely,
Ivan.
OpenWRT compilation for VoCore Ultimate
- eroshiva
Re: OpenWRT compilation for VoCore Ultimate
.dts is opensourced.
Please download at github.com/vonger/vocore2
It is in the patches.
- eroshiva
Alright, can you clarify correctness of following .dts files for VoCore 2 Ultimate? Did I miss something?
mt7628an_vocore_vocore2-ultimate.dtsi is following:
#include "mt7628an.dtsi"
#include <dt-bindings/gpio/gpio.h>
compatible = "vocore,vocore2", "mediatek,mt7628an-soc";
aliases {
label-mac-device = &wmac;
chosen {
bootargs = "console=ttyS2,115200";
&state_default {
gpio {
groups = "wled_an", "wdt";
function = "gpio";
refclk {
group = "gpio0";
function = "gpio refclk";
&wmac {
status = "okay";
ðernet {
mtd-mac-address = <&factory 0x28>;
&esw {
mediatek,portmap = <0x7>;
mediatek,portdisable = <0x3a>;
&i2s {
#sound-dai-cells = <0>;
status = "okay";
&gdma {
status = "okay";
&pwm {
status = "okay";
&uart1 {
status = "okay";
&uart2 {
status = "okay";
mt7628an_vocore_vocore2-ultimate.dts is following:
/dts-v1/;
#include "mt7628an_vocore_vocore2_ultimate.dtsi"
model = "VoCore2Ultimate";
aliases {
led-boot = &led_status;
led-failsafe = &led_status;
led-running = &led_status;
led-upgrade = &led_status;
leds {
compatible = "gpio-leds";
led_status: status {
label = "vocore2:fuchsia:status";
gpios = <&gpio 44 GPIO_ACTIVE_HIGH>;
sound {
compatible = "simple-audio-card";
name = "soundcard";
format = "i2s";
bitclock-master = <&sound_master>;
frame-master = <&sound_master>;
mclk-fs = <272>;
widgets =
"Microphone", "Microphone Jack",
"Headphone", "Headphone Jack";
routing =
"LINPUT1", "Microphone Jack",
"RINPUT1", "Microphone Jack",
"Microphone Jack", "Mic Bias",
"Headphone Jack", "LOUT1",
"Headphone Jack", "ROUT1";
cpu {
sound-dai = <&i2s>;
sound_master: codec {
sound-dai = <&codec>;
&i2c {
status = "okay";
codec: es8388@10 {
compatible = "everest,es8328";
reg = <0x10>;
clocks = <&clkctrl 20>;
clock-names = "refclk";
&spi0 {
status = "okay";
flash@0 {
compatible = "jedec,spi-nor";
reg = <0>;
spi-max-frequency = <10000000>;
partitions {
compatible = "fixed-partitions";
#address-cells = <1>;
#size-cells = <1>;
partition@0 {
label = "u-boot";
reg = <0x0 0x30000>;
read-only;
partition@30000 {
label = "u-boot-env";
reg = <0x30000 0x10000>;
read-only;
factory: partition@40000 {
label = "factory";
reg = <0x40000 0x10000>;
read-only;
partition@50000 {
compatible = "denx,uimage";
label = "firmware";
reg = <0x50000 0xfb0000>;
Is that correct?
aliases {
chosen {
&state_default {
gpio {
function = "gpio";
refclk {
group = "gpio0";
&wmac {
status = "okay";
ðernet {
&esw {
&i2s {
status = "okay";
&gdma {
status = "okay";
&pwm {
status = "okay";
&uart1 {
status = "okay";
&uart2 {
status = "okay";
/dts-v1/;
aliases {
leds {
sound {
name = "soundcard";
format = "i2s";
mclk-fs = <272>;
widgets =
routing =
cpu {
sound-dai = <&i2s>;
&i2c {
status = "okay";
codec: es8388@10 {
reg = <0x10>;
&spi0 {
status = "okay";
flash@0 {
reg = <0>;
partitions {
#size-cells = <1>;
partition@0 {
label = "u-boot";
read-only;
partition@30000 {
read-only;
label = "factory";
read-only;
partition@50000 {
label = "firmware";
Is that correct?
VOCORE2.dtsi and MT7628.dtsi we can use default one.
After patch, the VOCORE2.dts should be like this
/dts-v1/;
#include "VOCORE2.dtsi"
model = "VoCore2";
gpio-leds {
status {
gpios = <&gpio1 12 GPIO_ACTIVE_HIGH>;
sound {
simple-audio-card,name = "soundcard";
simple-audio-card,format = "i2s";
simple-audio-card,bitclock-master = <&sound_master>;
simple-audio-card,frame-master = <&sound_master>;
simple-audio-card,mclk-fs = <272>;
simple-audio-card,widgets =
simple-audio-card,routing =
simple-audio-card,cpu {
sound-dai = <&i2s>;
sound_master:simple-audio-card,codec {
&i2c {
status = "okay";
codec: es8388@10 {
reg = <0x10>;
&spi0 {
status = "okay";
cs-gpios = <&gpio0 6 GPIO_ACTIVE_HIGH>,
<&gpio0 10 GPIO_ACTIVE_HIGH>;
// <&gpio1 5 GPIO_ACTIVE_HIGH>,
// <&gpio1 6 GPIO_ACTIVE_HIGH>;
m25p80@0 {
#size-cells = <1>;
reg = <0>;
m25p,chunked-io = <32>;
partition@0 {
label = "u-boot";
read-only;
partition@30000 {
read-only;
label = "factory";
read-only;
partition@50000 {
label = "firmware";
spidev@1 {
#size-cells = <1>;
compatible = "rohm,dh2228fv";
reg = <1>;
spi-max-frequency = <100000000>;
spidev@2 {
#size-cells = <1>;
reg = <2>;
spidev@3 {
#size-cells = <1>;
reg = <3>;
&sdhci {
status = "okay";
mediatek,cd-poll;
Users browsing this forum: No registered users and 15 guests
