Breakout boards.
avigeilpro
Re: Breakout boards.
Fri Apr 14, 2017 2:47 am
Here is the mask if you want to build it by yourself (600 dpi, 1 layer):
I moved the PWM0 and PWM1 pins to the right side for a easier rooting on 1 layer.
Here are the gerber files, if you want order to a PCB fusion company (for example seeedstudio with 3 "e"), i changed for a 2 layer PCB, with this you will have the 2 pins PWM0 and PWM1 at the correct place :
Preview :
Image Image
Gerber files (zip file to give):
https://drive.google.com/open?id=0B0awE ... VhRNlhIdVk
headers for the vocore (step of 50th or 1.27mm) : http://www.ebay.fr/itm/142290958989?var=441340040244
pepemint
Sat May 06, 2017 6:25 am
Thank you very much @avigeilpro :)
I tried for the first time to etch a pcb by carefully following the instructions at http://www.instructables.com/id/Stop-us ... etter-etc/
It worked well! But then I had major problems drilling properly aligned holes for the 1.27mm headers... any guides for how you would drill those?
Anyway I uploaded the Gerber files to http://oshpark.com and they came back perfect.
iham
Wed May 31, 2017 8:02 am
avigeilpro, pls post me a PCB files of board. Thanks.
avigeilpro
Thu Jun 01, 2017 3:15 pm
iham wrote:avigeilpro, pls post me a PCB files of board. Thanks.
Sorry, i don't understand what you ask for ?
iham
Thu Jun 01, 2017 6:50 pm
Sorry, I did't see the second page of the discussion. =) Already downloaded, thanks. Cool board!
avigeilpro
Fri Jun 02, 2017 6:10 pm
you welcome ;)
elispapa2010
Tue Sep 15, 2020 8:47 pm
Have any more of the breakout boards?
Previous
Users browsing this forum: No registered users and 28 guests
