If you put an image on it that won't even fully boot up you will need to use uboot.
When the VoCore2 boots up you will see this on a serial connection:
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM component: 512 Mbits DDR, width 16
DRAM bus: 16 bit
Total memory: 64 MBytes
Flash component: SPI Flash
Date:Jun 25 2016 Time:09:25:16
RESET MT7628 PHY!!!!!!
Please choose the operation:
If you have a USB memory stick the easiest way to load an image is to put it on the stick, rename it "root_uImage", plug it into the USB host connector of the VoCore2 and use option 5. The USB drive has to be formatted vfat, most of them come that way.
I recommend my
image, see
this post for details.
