AP+STA Help Please SOLVED
Posted: Thu Dec 15, 2016 7:19 am
Hello
I'm trying to connect with AP+STA so I can run "opkg update" and install python mini but I'm having difficulty. I believe it connects to my router OK but it doesn't allow the downloads for "opkg update". Here's what iwinfo says, my home network name is "GXS4N":
apcli0 ESSID: "GXS4N"
Access Point: 18:1B:EB:C3:4C:81
Mode: Client Channel: 6 (2.437 GHz)
Tx-Power: 17 dBm Link Quality: unknown/100
Signal: unknown Noise: unknown
Bit Rate: 150.0 MBit/s
Encryption: unknown
Type: wext HW Mode(s): 802.11bg
Hardware: unknown [Generic WEXT]
TX power offset: unknown
Frequency offset: unknown
Supports VAPs: no PHY name: apcli0
apcli1 ESSID: unknown
Access Point: 00:00:00:00:00:00
Encryption: unknown
Supports VAPs: no PHY name: apcli1
ra0 ESSID: "VoCore2"
Access Point: 00:0C:43:E1:76:28
Tx-Power: 17 dBm Link Quality: 10/100
Signal: -256 dBm Noise: -70 dBm
Encryption: unknown
Supports VAPs: no PHY name: ra0
And cat /etc/config/network:
config interface 'loopback'
option ifname 'lo'
option proto 'static'
option ipaddr '127.0.0.1'
option netmask '255.0.0.0'
config globals 'globals'
option ula_prefix 'fd47:f447:6340::/48'
config interface 'lan'
option ifname 'eth0.1'
option force_link '1'
option macaddr '00:0c:43:e1:76:28'
option type 'bridge'
option ipaddr '192.168.1.1'
option netmask '255.255.255.0'
option ip6assign '60'
config interface 'wan'
option ifname 'eth0.2'
option macaddr '00:0c:43:e1:76:29'
option proto 'dhcp'
config interface 'wan6'
option proto 'dhcpv6'
config switch
option name 'switch0'
option reset '1'
option enable_vlan '1'
config switch_vlan
option device 'switch0'
option vlan '1'
option ports '1 2 3 4 6t'
config switch_vlan
option vlan '2'
option ports '0 6t'
Encryption: unknown
Encryption: unknown
Encryption: unknown
option ifname 'lo'
option proto 'dhcp'
config switch
option reset '1'
config switch_vlan
option vlan '1'
config switch_vlan
option vlan '2'
option ports '0 6t'
