Pls help me iusse : mmc0: error -22 whilst initialising MMC
Posted: Tue Dec 27, 2016 4:33 am
help me, My vocore2+AirPlay Dock firest time power on , I can find VoCore2 in my computer hotspot list. I do this:
Then re-power on , I can't find VoCore2 in my computer hotspot list. I use minicom from usb cable in unbutu 16.04 , show this: (what i do ?)
_______ ________ __
* 1 1/2 oz Gin Shake with a glassful
* 1/4 oz Triple Sec of broken ice and pour
* 3/4 oz Lime Juice unstrained into a goblet.
* 1 1/2 oz Orange Juice
* 1 tsp. Grenadine Syrup
root@OpenWrt:~# uci set wireless.sta.ssid=zhai-home
root@OpenWrt:~# uci set wireless.sta.key=5722323123
root@OpenWrt:~# uci set wireless.sta.network=wwan
root@OpenWrt:~# uci set wireless.sta.disabled=0
root@OpenWrt:~# uci commit
root@OpenWrt:~# /etc/init.d/network restart
Uncompressing Kernel Image ... s 80000000) ...
Startn 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 6
[ 0.000000] Board has DDR2
[ 0.000000] Analog PMU sol
[ 0.000000] SoC Type: MediaTek MT7628AN ver:1 eco:2
[ 0.000000] MIPS: machine is VoCore2
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x00000000-0x
[ 0.000000] n[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, line.
[ 0.inesize 32 bytes
[ 0.000000] al pages: 32512
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 6ries: 8192 (orde)
[ 0.000000] Writing ErrCtl register=0007e00e
[ 0.000000] Readback ErrCtl register=0007e00e
[ 0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata, e
[ 0.000000] CPU Clock: 580MHz
[ 0.000000] clocksource_of_init: no matching clocksources found
[ 0.000385.84 Bogminimum: 301
[ 0.060000] Mount-cache hash table entrieche hash table entries: 1024 (order: 0)
[ 0.070000] pinctrl core: initialized pinctrl subsystem
[ 0.080000] NET: Registered protocol family 16
[ 0.100000] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.110000] mt7621_gpio 10000600.gpio: registering 32 gpios
[ 0.110000] mt7621_gpio 10000600.gpioS
[ 0.120000] NET: Registered protocol table entries: 1024 (order: 0, 4096 bytes)
[ 0.130000] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.140000] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.140000] TCP: reno registered
[ 0.150000] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 6 bytes)
[ 0.160000] NET: Registered protocol family 1
[ 0.170000] futex hash table entries[ 0.180000] squashfs: version 4.0 (2009/r
[ 0.190000] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY).
[ 0.200000] msgmni has been set [ 0.210000] io scheduler noop registered
[ 0.210000] io scheduler deadline registered (default)
[ 0.220000] gdma-mt7628 10002800.gdma: revision: 3, channels: 16
d00 (irq = 29, base_baud = 2500000) is a 16550Ais a 16550Aring disabled
[ 0.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.270000] console [ttyS2] enabledbootconsole [early0] disabled
[ 0.270000] bootconsolei-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.290000] m25p80 spi32766.0: found gd25q128, expected en25q64
[ 0.300000] m25p80 spi32766.0: gd25q128 chunked io
[ 0.310000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.320000] Creating 4 MTD partitions on "spi32766.0":
[ 0.320000] 0x000000000000-"
[ 0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.330000] 0x000000040000-0x000000050000 : "factory"
[ 0.340000] 0x000000050000-0x000001000000 : "firmware"
[ 0.410000] 2 uimage-fw partitions found on MTD device firmware
[ 0.410000] 0x000000050000-0x000000167d15 : "kernel"
[ 0.420000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.430000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.440000] 0x00[ 0.450000] ralink_soc_eth 10100000.ethernet: generated rand8
[ 0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.470000] mt7621_wdt 10000120.watchdog: d
[ 0.480000] NET: Registered protocol family 17
[ 0.480000] bridge: automatic filtering via arp/ip/ip6tables has been deprecate.
[ 0.520000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
AT
[ 2.310000] init: Console is alive
[ 2.320000] init: - watchdog -
AT
registered new interface driver usbfs
[ 5.840000] usbcore: registered new interface driver hub
[ 5.850000] usbcore: registered new device driver usb
[ 5.860000] exFAT: Version 1.2.9
.930000] ehci-platform: EHCI generic platform driver
[ 5.950000] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 5.960000] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 5.960000] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 5.970000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus n1
[ 5.970000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 6.000000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 6.000000:1.0: 1 port detected
[ 6.010000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 6.020000] ohci-platform: OHCI generic platform driver
[ 6.030000] ohci-platform 101c1000.ohci: Generic Platform OHCI controllbus regi2
[ 6.040000] o[ 6.110000] hub 2-0:1.0: USB hub found
[ 6.110000] hub 2-0:1.0: 1 port detected
[ 6.130000] MTK MSDC device init.
[ 6.170000] mtk-sd: MediaTek MT6575 MSDC Driver
[ 6.170000] sdhci: Secure Digital Host Controller Interface driver
[ 6.180000] sdhci: Copyright(c) Pierre Ossmai-pltfm: SDHCI platform and OF drivr
[ 6.200000] usbcore: registered new interface driver usb-storage
[ 6.210000] mtk-sd 1013000[ 6.220000] mtk-sd 10130000.sdhci: no support for s
[ 6.230000] mmc0: [ 6.270000] mtk-sd 10130000.sdhci: no support for card's vs
[ 6.280000] mmc0: error - 6.280000] mtk-sd 10130000.sdhci: no support for cad
i: no support for card's volts
[ 6.350000] mmc0: error -22 whilst initialising SDIO card
[ 6.350000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.360000] mmc0: error -22 whilst initialising MMC card
AT[ 7.430000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.440000] mmc0: error -22 whilst initialising SDIO card
[ 7.440000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.450000] mmc0: error -22 whilst initialising MMC card
[ 7.510000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.520000] mmc0: error -22 whilst initialising SDIO card
[ 7.540000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.540000] mmc0: error -22 whilst initialising MMC card
.740000] rt305x-esw 10110000.esw: link changed 0x00
[ 7.890000] mtk-sd 10130000: error -22 whilst initialising SDIO card
[ 7.910000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.910000] mmc0: error -22 whilst initialising MMC card
[ 8.970000] mtk-sd 10130000.sdhci: no supilst initialising SDIO card
[ 8.980000] mtk-sd 10130000.sdhci: no support for card's volts
[ 8.990000] mmc0: error -22 whilst initialising MMC card
[ 9.040000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.050000] mmc0: error -22 whilst initialising SDIO card
[ 9.050000] mtk-sd 10130000.sdhci: no support for carding MMC card
[ 9.120000] mmc0: error -22 whilst initialising SDIO card
[ 9.120000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.130000] mmc0: error -22 whilst initialising MMC card
[ 10.210000] mount_root: loading kmods from internal overlay
[ 10.290000] mtk-sd 10130000.sdhci: no support for card's volts
[ 10.300000] mmc0: error -22 wh00] mtk-sd 10130000.sdhci: no support for card's s
rd
~^@x�~[ 10.370000] mtk-sd 10130000.sdhci: no support for card's volts
[ 10.380000] mmc0: error[ 10.390000] mtk-sd10130000.sdhci: no support for cards
[ 10.390000] mmc0: error -22 whilst initialising MMC card
[ 10.450000] mtk-sd 10130000.sdhci: no support for card's volts
[ 10.460000] mmc0: e[ 10.470000] mtk470000] mmc0: error -22 whilst initialisind
ld_xattr_subsystem: complete building xattr subsystem, 0 0 orphan) found.
[ 10.970000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
11.040000] block: extroot: not configured
jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 uny
hilst initialising[ 11.570000] mtk-sd 1013mc0: error -22 whilst initialising MMCd
[ 11.680000] mtk-sd 00] mmc0: error -22 whilst initialising MMC card
[ 11.760000] mmc0: e[ 11.780000] mtk-sd 10130000.sdhci: no support for card's s
[ 11.7[ 11.820000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fsb
[ 11.920000] procd: - early -
[ 11.920000] procd: - watchdog -
[ 12.830000] procd: - ubus -
[ 12.930000] mtk-sd 10130000[ 12.950[ 12.960000] mmc0: error -22 whilst initd
[ 13.030000] mmc0: error -22 whilst initialising SDIO card
[ 13.040000] mtk-sd 10130000.sdhci: no support for card's volts
[ 13.040000] mmc0: error -22 whilst initialising MMC card
[ 13.840000] procd: - init -
[ 14.260000] mtk-sd 10130000.sdhci: no support for card's volts
[ 14.270000] mmc0: error -22 whilst initialising SDIO card
[ 14.280000] mtk-sd 10130000.sdhci: no support for card's volts
[ 14.280000] mmc0: error -22 whilst initialising MMC card
[ 14.340000] mtk-sd 10130000.sdhci: no support for card's volts
[ 14.350000] mmc0: error -22 whilst initialising SDIO card
[ 14.360000] mtk-sd 10130000.sdhci: no support for card's volts
[ 14.360000] mmc0: error -22 whilst initialising MMC card
[ 14.420000] mtk-sd 10130000.sdhci: no support for card's volts
[ 14.430000] mmc0: error -22 whilst initialising SDIO card
[ 14.440000] mtk-sd 10130000.sdhci: no support for card's volts
[ 14.440000] mmc0: error -22 whilst initialising MMC card
[ 15.280000] NET: Registered protocol family 10
[ 15.350000] ntfs: driver 2.1.31 [Flags: R/O MODULE].
[ 15.450000] tun: Universal TUN/TAP device driver, 1.6
[ 15.460000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 15.490000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 15.510000] mtk-sd 10130000.sdhci: no support for card's volts
[ 15.520000] mmc0: error -22 whilst initialising SDIO card
[ 15.540000] mtk-sd 10130000.sdhci: no support for card's volts
[ 15.540000] mmc0: error -22 whilst initialising MMC card
[ 15.550000] i2c /dev entries driver
[ 15.620000] mtk-sd 10130000.sdhci: no support for card's volts
[ 15.630000] mmc0: error -22 whilst initialising SDIO card
[ 15.660000] mtk-sd 10130000.sdhci: no support for card's volts
[ 15.660000] mmc0: error -22 whilst initialising MMC card
[ 15.920000] mtk-sd 10130000.sdhci: no support for card's volts
[ 15.930000] mmc0: error -22 whilst initialising SDIO card
[ 16.030000] mtk-sd 10130000.sdhci: no support for card's volts
[ 16.030000] mmc0: error -22 whilst initialising MMC card
[ 16.840000] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
[ 16.840000] <-- RTMPAllocAdapterBlock, Status=0
[ 16.880000] i2c-gpio i2c-gpio: using pins 5 (SDA) and 4 (SCL)
[ 16.900000] Linux video capture interface: v2.00
[ 16.920000] mt7628-i2s 10000a00.i2s: loaded, sys freq is 480MHz.
[ 16.930000] es8388_codec_probe
[ 16.930000] es8388_reset
[ 16.940000] set system reference clock(mclk) to 12MHz.
[ 16.950000] mt7628-audio audio-card: es8388-hifi <-> 10000a00.i2s mapping ok
[ 16.960000] mt7628-audio audio-card: load
[ 16.970000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 16.990000] nf_conntrack version 0.5.0 (1976 buckets, 7904 max)
[ 17.030000] usbcore: registered new interface driver uvcvideo
[ 17.030000] USB Video Class driver (1.1.1)
[ 17.060000] xt_time: kernel timezone is -0000
[ 17.070000] PPP generic driver version 2.4.2
[ 17.080000] NET: Registered protocol family 24
[ 17.100000] mtk-sd 10130000.sdhci: no support for card's volts
[ 17.110000] mmc0: error -22 whilst initialising SDIO card
[ 17.110000] mtk-sd 10130000.sdhci: no support for card's volts
[ 17.120000] mmc0: error -22 whilst initialising MMC card
[ 17.170000] mtk-sd 10130000.sdhci: no support for card's volts
[ 17.180000] mmc0: error -22 whilst initialising SDIO card
[ 17.180000] mtk-sd 10130000.sdhci: no support for card's volts
[ 17.190000] mmc0: error -22 whilst initialising MMC card
[ 17.240000] mtk-sd 1013+-----------------------------+'s volts
[ 17.250000] mmc0: error| |ard
[ 17.250000] mtk-sd 1013| Cannot open /dev/ttyACM0! |'s volts
[ 17.260000] mmc0: error| |rd
[ 18.320000] mtk-sd 1013+-----------------------------+'s volts
[ 18.320000] mmc0: error -22 whilst initialising SDIO card
[ 18.330000] mtk-sd 10130000.sdhci: no support for card's volts
[ 18.340000] mmc0: error -22 whilst initialising MMC card
[ 18.540000] mtk-sd 10130000.sdhci: no support for card's volts
[ 18.540000] mmc0: error -22 whilst initialising SDIO card
[ 18.560000] mtk-sd 10130000.sdhci: no support for card's volts
[ 18.560000] mmc0: error -22 whilst initialising MMC card
[ 18.630000] mtk-sd 10130000.sdhci: no support for card's volts
[ 18.640000] mmc0: error -22 whilst initialising SDIO card
[ 18.650000] mtk-sd 10130000.sdhci: no support for card's volts
[ 18.650000] mmc0: error -22 whilst initialising MMC card
