Help with TTY connection, error
Posted: Wed Dec 28, 2016 3:29 am
I'm trying to connect to Vocore2 by TTY to enable the wifi on my Vocore but I keep getting an error message and I don't know whats going on.
Kermit> connect
Connecting to /dev/tty.usbserial, speed 115200
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
You chose 3
0
Image Name: MIPS OpenWrt Linux-3.18.29
Data Size: 1146069 Bytes = 1.1 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49378) ) #22 Sun Oct 16 21:00:17 CST 2016
[ 0.000000] Board has DDR2
[ 0.000000] Zone ranges:
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[ 0.000000] Writing ErrCtl register=00061146
[ 0.000000] Readback ErrCtl register=00061146
[ 0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata, 520K rodata, 136K init, 186K bss, 4732K reserved)
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 580MHz
[ 0.230000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.240000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.250000] console [ttyS2] disabled
[ 0.260000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.270000] console [ttyS2] enabled
[ 0.270000] bootconsole [early0] disabled
[ 0.280000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.290000] m25p80 spi32766.0: found w25q128, expected en25q64
[ 0.300000] m25p80 spi32766.0: w25q128 (16384 Kbytes)
[ 0.300000] m25p80 spi32766.0: using chunked io
[ 0.310000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.320000] Creating 4 MTD partitions on "spi32766.0":
[ 0.320000] 0x000000000000-0x000000030000 : "u-boot"
[ 0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.330000] 0x000000040000-0x000000050000 : "factory"
[ 0.340000] 0x000000050000-0x000001000000 : "firmware"
[ 0.410000] 2 uimage-fw partitions found on MTD device firmware
[ 0.410000] 0x000000050000-0x000000167d15 : "kernel"
[ 0.420000] 0x000000167d15-0x000001000000 : "rootfs"
[ 0.420000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.430000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.440000] 0x0000006a0000-0x000001000000 : "rootfs_data"
[ 0.450000] ralink_soc_eth 10100000.ethernet: generated random MAC address 76:06:2f:92:e1:1a
[ 0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.470000] mt7621_wdt 10000120.watchdog: Initialized
[ 0.480000] TCP: cubic registered
[ 0.480000] NET: Registered protocol family 17
[ 0.480000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.500000] 8021q: 802.1Q VLAN Support v1.8
[ 0.520000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.520000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
[ 2.310000] init: Console is alive
[ 2.320000] init: - watchdog -
[ 5.840000] usbcore: registered new interface driver usbfs
[ 5.850000] usbcore: registered new interface driver hub
[ 5.850000] usbcore: registered new device driver usb
[ 5.870000] exFAT: Version 1.2.9
[ 5.920000] SCSI subsystem initialized
[ 5.930000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.940000] ehci-platform: EHCI generic platform driver
[ 5.950000] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 5.960000] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 5.960000] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 5.970000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 5.980000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 6.010000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 6.010000] hub 1-0:1.0: USB hub found
[ 6.020000] hub 1-0:1.0: 1 port detected
[ 6.020000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 6.030000] ohci-platform: OHCI generic platform driver
[ 6.040000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 6.040000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 6.050000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 6.120000] hub 2-0:1.0: USB hub found
[ 6.120000] hub 2-0:1.0: 1 port detected
[ 6.140000] MTK MSDC device init.
[ 6.180000] mtk-sd: MediaTek MT6575 MSDC Driver
[ 6.180000] sdhci: Secure Digital Host Controller Interface driver
[ 6.190000] sdhci: Copyright(c) Pierre Ossman
[ 6.200000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.210000] usbcore: registered new interface driver usb-storage
[ 6.220000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.220000] mmc0: error -22 whilst initialising SDIO card
[ 6.230000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.240000] mmc0: error -22 whilst initialising MMC card
[ 6.280000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.290000] mmc0: error -22 whilst initialising SDIO card
[ 6.290000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.300000] mmc0: error -22 whilst initialising MMC card
[ 6.350000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.360000] mmc0: error -22 whilst initialising SDIO card
[ 6.360000] mtk-sd 10130000.sdhci: no support for card's volts
[ 6.370000] mmc0: error -22 whilst initialising MMC card
[ 6.440000] init: - preinit -
[ 7.440000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.450000] mmc0: error -22 whilst initialising SDIO card
[ 7.470000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.470000] mmc0: error -22 whilst initialising MMC card
[ 7.540000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.550000] mmc0: error -22 whilst initialising SDIO card
[ 7.740000] rt305x-esw 10110000.esw: link changed 0x00
[ 7.890000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.890000] mmc0: error -22 whilst initialising MMC card
[ 7.940000] random: mktemp urandom read with 13 bits of entropy available
[ 7.960000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.960000] mmc0: error -22 whilst initialising SDIO card
[ 7.980000] mtk-sd 10130000.sdhci: no support for card's volts
[ 7.980000] mmc0: error -22 whilst initialising MMC card
[ 9.050000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.060000] mmc0: error -22 whilst initialising SDIO card
[ 9.060000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.070000] mmc0: error -22 whilst initialising MMC card
[ 9.110000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.120000] mmc0: error -22 whilst initialising SDIO card
[ 9.120000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.130000] mmc0: error -22 whilst initialising MMC card
[ 9.180000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.190000] mmc0: error -22 whilst initialising SDIO card
[ 9.190000] mtk-sd 10130000.sdhci: no support for card's volts
[ 9.200000] mmc0: error -22 whilst initialising MMC card
[ 10.250000] mtk-sd 10130000.sdhci: no support for card's volts
[ 10.260000] mmc0: error -22 whilst initialising SDIO card
Kermit> connect
DRAM bus: 16 bit
GPIO 46 is low
You chose 3
0
No initrd
Starting kernel ...
