[SOLVED] no connection as AP
harvey186
Wed Dec 28, 2016 4:44 pm
Hi;
I'm sorry, I'm very new on router an AP setup.
I have a local network with an router from my local ISP. I want use Vocore2 as an access point (and later as an TOR ap). I have done the complete setup from vongers webpage. As SSID I have used the SSID from my router. Same I have done with the key. But when I have a look on the router client List, I can't see the Vocore. So what's wrong ?
Thanks for helping me.
cat /etc/config/wireless
config wifi-device 'radio0'
.option type 'ralink'
.option variant 'mt7628'
.option country 'CN'
.option hwmode '11g'
.option htmode 'HT40'
.option channel 'auto'
.option disabled '0'
config wifi-iface 'ap'
.option device 'radio0'
.option mode 'ap'
.option network 'lan'
.option ifname 'ra0'
.option ssid 'VoCore2'
.option encryption 'none'
config wifi-iface 'sta'
.option mode 'sta'
.option network 'wwan'
.option ifname 'apcli0'
.option led 'mediatek:orange:wifi'
.option encryption 'psk'
.option key 'RouterWPA key'
.option ssid 'Router-SSID'
.option disabled '1'
PS. I have written the same post before, but I can't find the post in the forum. So I have created a new post. So I hope, this is no double post.
Re: no connection as AP
Thu Dec 29, 2016 2:07 am
.option mode 'ap'
why before the option there is a point '.'?
Maybe remove it will fix such issue.
harvey186
Thu Dec 29, 2016 9:32 am
Today I can "see" the Vocore as "unknown" device in my router clients list. I can ssh 192.168.0.137 and get a connection to the VoCore2. But all my other devices (smartphone/tablet/desktop) can't find the "unknown" device.
root@OpenWrt:~# ifconfig
apcli0    Link encap:Ethernet  HWaddr BA:D8:12:07:11:A3
          inet addr:192.168.0.137  Bcast:192.168.0.255  Mask:255.255.255.0
          inet6 addr: fe80::b8d8:12ff:fe07:11a3/64 Scope:Link
          collisions:0 txqueuelen:1000
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
br-lan    Link encap:Ethernet  HWaddr B8:D8:12:67:11:A3
          inet addr:192.168.61.1  Bcast:192.168.61.255  Mask:255.255.255.0
          inet6 addr: fe80::bad8:12ff:fe67:11a3/64 Scope:Link
          inet6 addr: fd7a:be73:d187::1/60 Scope:Global
          RX packets:434 errors:0 dropped:0 overruns:0 frame:0
          TX packets:530 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:33964 (33.1 KiB)  TX bytes:55929 (54.6 KiB)
eth0      Link encap:Ethernet  HWaddr 1E:D2:C7:A7:AC:7B
          inet6 addr: fe80::1cd2:c7ff:fea7:ac7b/64 Scope:Link
          TX packets:354 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:73947 (72.2 KiB)
          Interrupt:5
eth0.1    Link encap:Ethernet  HWaddr 1E:D2:C7:A7:AC:7B
          TX packets:118 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:17136 (16.7 KiB)
eth0.2    Link encap:Ethernet  HWaddr B8:D8:12:67:11:A4
          inet6 addr: fe80::bad8:12ff:fe67:11a4/64 Scope:Link
          TX packets:142 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:40360 (39.4 KiB)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING  MTU:65536  Metric:1
          RX packets:444 errors:0 dropped:0 overruns:0 frame:0
          TX packets:444 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:30048 (29.3 KiB)  TX bytes:30048 (29.3 KiB)
ra0       Link encap:Ethernet  HWaddr B8:D8:12:67:11:A3
          RX packets:8444 errors:6 dropped:0 overruns:0 frame:0
          TX packets:2810 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:2132057 (2.0 MiB)  TX bytes:112455 (109.8 KiB)
          Interrupt:6
Thu Dec 29, 2016 3:56 pm
check /etc/config/firewall
it might block the network.
harvey186
Re: [SOLVED] no connection as AP
Thu Dec 29, 2016 3:57 pm
Thx, It's working now.
