"I can't get no", wifi connection! (home ap)
Posted: Thu Dec 29, 2016 6:27 am
Hello guys,
I got a VoCore2 Ultimate for the holidays and having a hard time setting it up. i cannot seem to connect to my home network. i tried multiple times in different ways (webgui, ssh, serial) but nothing works. I have added my bootprocess output below. maybe someone can find the problem?
root@OpenWrt:/bin/vocoremon# reboot
root@OpenWrt:/bin/vocoremon# [ 567.210000] br-lan: port 1(eth0.1) entered disabled state
[ 567.240000] device eth0.1 left promiscuous mode
[ 567.240000] br-lan: port 1(eth0.1) entered disabled state
[ 567.250000] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 567.480000] device eth0 left promiscuous mode
[ 571.480000] reboot: Restarting system
Ralink UBoot Version: 4.3.0.0
ASIC 7628_MP (Port5<->None)
DRAM bus: 16 bit
Total memory: 128 MBytes
Flash component: SPI Flash
RESET MT7628 PHY!!!!!!
Please choose the operation:
gpio trigger enabled
GPIO 46 is low
0
Image Name: MIPS OpenWrt Linux-3.18.29
Data Size: 1146194 Bytes = 1.1 MB
Load Address: 80000000
Entry Point: 80000000
Verifying Checksum ... OK
No initrd
Starting kernel ...
[ 0.000000] Linux version 3.18.29 (vocore@ubuntu) (gcc version 4.8.3 (OpenWrt/Linaro GCC 4.8-2014.04 r49378) ) #32 Sat Dec 24 22:01:05 CST 2016
[ 0.000000] Board has DDR2
[ 0.000000] Zone ranges:
[ 0.000000] Kernel command line: console=ttyS2,115200 rootfstype=squashfs,jffs2
[ 0.000000] Writing ErrCtl register=000387dc
[ 0.000000] Readback ErrCtl register=000387dc
[ 0.000000] Memory: 126340K/131072K available (2530K kernel code, 131K rwdata, 520K rodata, 136K init, 186K bss, 4732K reserved)
[ 0.000000] NR_IRQS:256
[ 0.000000] CPU Clock: 580MHz
[ 0.230000] 10000c00.uartlite: ttyS0 at MMIO 0x10000c00 (irq = 28, base_baud = 2500000) is a 16550A
[ 0.240000] 10000d00.uart1: ttyS1 at MMIO 0x10000d00 (irq = 29, base_baud = 2500000) is a 16550A
[ 0.250000] console [ttyS2] disabled
[ 0.260000] 10000e00.uart2: ttyS2 at MMIO 0x10000e00 (irq = 30, base_baud = 2500000) is a 16550A
[ 0.270000] console [ttyS2] enabled
[ 0.270000] bootconsole [early0] disabled
[ 0.280000] spi-mt7621 10000b00.spi: sys_freq: 193333333
[ 0.290000] m25p80 spi32766.0: found gd25q128, expected en25q64
[ 0.300000] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[ 0.300000] m25p80 spi32766.0: using chunked io
[ 0.310000] 4 ofpart partitions found on MTD device spi32766.0
[ 0.320000] Creating 4 MTD partitions on "spi32766.0":
[ 0.320000] 0x000000000000-0x000000030000 : "u-boot"
[ 0.330000] 0x000000030000-0x000000040000 : "u-boot-env"
[ 0.330000] 0x000000040000-0x000000050000 : "factory"
[ 0.340000] 0x000000050000-0x000001000000 : "firmware"
[ 0.410000] 2 uimage-fw partitions found on MTD device firmware
[ 0.410000] 0x000000050000-0x000000167d92 : "kernel"
[ 0.420000] 0x000000167d92-0x000001000000 : "rootfs"
[ 0.420000] mtd: device 5 (rootfs) set to be root filesystem
[ 0.430000] 1 squashfs-split partitions found on MTD device rootfs
[ 0.440000] 0x0000006f0000-0x000001000000 : "rootfs_data"
[ 0.450000] ralink_soc_eth 10100000.ethernet: generated random MAC address ee:31:2d:70:64:3a
[ 0.460000] ralink_soc_eth 10100000.ethernet eth0: ralink at 0xb0100000, irq 5
[ 0.470000] mt7621_wdt 10000120.watchdog: Initialized
[ 0.470000] TCP: cubic registered
[ 0.480000] NET: Registered protocol family 17
[ 0.480000] bridge: automatic filtering via arp/ip/ip6tables has been deprecated. Update your scripts to load br_netfilter if you need this.
[ 0.500000] 8021q: 802.1Q VLAN Support v1.8
[ 0.510000] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
[ 0.520000] Freeing unused kernel memory: 136K (8031e000 - 80340000)
[ 2.320000] init: Console is alive
[ 2.320000] init: - watchdog -
[ 5.850000] usbcore: registered new interface driver usbfs
[ 5.860000] usbcore: registered new interface driver hub
[ 5.870000] usbcore: registered new device driver usb
[ 5.880000] exFAT: Version 1.2.9
[ 5.930000] SCSI subsystem initialized
[ 5.940000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 5.950000] ehci-platform: EHCI generic platform driver
[ 5.960000] phy phy-10120000.usbphy.0: remote usb device wakeup disabled
[ 5.970000] phy phy-10120000.usbphy.0: UTMI 16bit 30MHz
[ 5.980000] ehci-platform 101c0000.ehci: EHCI Host Controller
[ 5.980000] ehci-platform 101c0000.ehci: new USB bus registered, assigned bus number 1
[ 5.990000] ehci-platform 101c0000.ehci: irq 26, io mem 0x101c0000
[ 6.020000] ehci-platform 101c0000.ehci: USB 2.0 started, EHCI 1.00
[ 6.020000] hub 1-0:1.0: USB hub found
[ 6.030000] hub 1-0:1.0: 1 port detected
[ 6.030000] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 6.040000] ohci-platform: OHCI generic platform driver
[ 6.050000] ohci-platform 101c1000.ohci: Generic Platform OHCI controller
[ 6.050000] ohci-platform 101c1000.ohci: new USB bus registered, assigned bus number 2
[ 6.060000] ohci-platform 101c1000.ohci: irq 26, io mem 0x101c1000
[ 6.130000] hub 2-0:1.0: USB hub found
[ 6.130000] hub 2-0:1.0: 1 port detected
[ 6.150000] MTK MSDC device init.
[ 6.190000] mtk-sd: MediaTek MT6575 MSDC Driver
[ 6.190000] sdhci: Secure Digital Host Controller Interface driver
[ 6.200000] sdhci: Copyright(c) Pierre Ossman
[ 6.210000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 6.220000] usbcore: registered new interface driver usb-storage
[ 6.440000] init: - preinit -
[ 7.700000] rt305x-esw 10110000.esw: link changed 0x00
[ 7.900000] random: mktemp urandom read with 13 bits of entropy available
[ 11.130000] mount_root: loading kmods from internal overlay
[ 11.790000] jffs2: notice: (374) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 11.810000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 11.830000] block: extroot: not configured
[ 11.980000] jffs2: notice: (371) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[ 12.000000] mount_root: loading kmods from internal overlay
[ 12.520000] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
[ 12.540000] block: extroot: not configured
[ 12.540000] mount_root: switching to jffs2 overlay
[ 12.580000] procd: - early -
[ 12.580000] procd: - watchdog -
[ 13.490000] procd: - ubus -
Command failed: Not found
[ 14.600000] procd: - init -
[ 15.980000] NET: Registered protocol family 10
[ 16.050000] ntfs: driver 2.1.31 [Flags: R/O MODULE].
[ 16.180000] tun: Universal TUN/TAP device driver, 1.6
[ 16.180000] tun: (C) 1999-2004 Max Krasnyansky <maxk@qualcomm.com>
[ 16.200000] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 16.230000] i2c /dev entries driver
[ 17.300000] <-- RTMPAllocTxRxRingMemory, Status=0, ErrorValue=0x
[ 17.310000] <-- RTMPAllocAdapterBlock, Status=0
[ 17.340000] i2c-gpio i2c-gpio: using pins 5 (SDA) and 4 (SCL)
[ 17.360000] Linux video capture interface: v2.00
[ 17.390000] mt7628-i2s 10000a00.i2s: loaded, sys freq is 480MHz.
[ 17.400000] es8388_codec_probe
[ 17.400000] set system reference clock(mclk) to 12MHz.
[ 17.410000] mt7628-audio audio-card: es8388-hifi <-> 10000a00.i2s mapping ok
[ 17.420000] mt7628-audio audio-card: load
[ 17.430000] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 17.450000] nf_conntrack version 0.5.0 (1976 buckets, 7904 max)
[ 17.480000] usbcore: registered new interface driver usblp
[ 17.500000] usbcore: registered new interface driver uvcvideo
[ 17.500000] USB Video Class driver (1.1.1)
[ 17.530000] xt_time: kernel timezone is -0000
[ 17.550000] PPP generic driver version 2.4.2
[ 17.560000] NET: Registered protocol family 24
[ 24.690000] device eth0.1 entered promiscuous mode
[ 24.690000] device eth0 entered promiscuous mode
[ 24.720000] br-lan: port 1(eth0.1) entered forwarding state
[ 26.720000] br-lan: port 1(eth0.1) entered forwarding state
[ 60.310000] random: nonblocking pool is initialized
